Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-17-2015, 02:58 PM
ESO6200 ESO6200 is offline
Re: Buick regal over heating
Originally Posted by Ruley73 View Post
Yes, there are two of them. Don't install the plastic ones because they will fail again within a few years.
Okay thanks ill look fr the other one
Old 01-17-2015, 10:00 PM
Also. Can these two elbow tubes be the a factor in why my car over heats? Because the radiator gets no water unles i put some . But therefore leaks out tru the tubes. .. Iguess i just kinda answeed my questio. Lol. But just wanna make sure
Old 01-18-2015, 01:20 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Yes, the leaky elbows will definitely cause overheating.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 01-18-2015, 09:41 AM
Alright . Hopefully this takes car of the problem. Thanks alot for the help tho. One more question.. What can be the cause to why my fan turns on late? Almost the to the point of the needle hitting the "H" ?
Old 01-18-2015, 12:27 PM
Ruley73's Avatar
I wouldn't worry about it. As long as they turn on, that's all that matters. The car is probably designed like that. Like I said earlier, the engine has to get hot enough before the fans will turn on. Usually, the only time the fan needs to turn on is coincidentally, when it's hot outside which is when most people turn the A/C on. Even when the A/C is turned on, the cooling fans are usually programmed to turn off when driving at highway speeds - again, unless the engine gets hot enough.
Just as an example, we've had our Equinox for over six years. I don't think the fan has ever turned on by itself to only cool the engine down (with A/C turned off). It hasn't been necessary though either. The temp gauge very rarely gets past the mid point.
My rides:
- Steve Smith (Red)
Old 01-18-2015, 03:06 PM
Ohokay got you. Best way to explain it. Thanks alot .
