Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-03-2014, 07:48 PM
j cAT j cAT is offline
Re: 99 Suburban ready codes
Originally Posted by gorent View Post
I do have a code reader and can clear codes, however I never get any fault codes that turn on "MIL" lights. I have been trying to get the ready monitors (5) to move from Not Ready to Ready. I have not had a fault code on over a year now. I hope this mileage thing works out. I will let you know how it does and at what mileage.
keep the fuel tank 1/3 to 3/4 full.. this will get those evap codes done ! after 100 miles you should have 3 monitors in the ready state.. those other monitors take a bit more time..
Old 09-09-2014, 01:55 AM
gorent gorent is offline
Well that may explain why the 5 monitors did not clear in over 724 miles and 20+ cold starts! Everytime I was told to disconnect cables from battery as told I was resetting mileage recorder to zero. I will be trying this 300-500 mile plan and see what happens. Thank you again!
Well.... 456 miles and 16 cold starts so far and 5 monitors have not moved off of incomplete status. $146.00 worth of gas and a lot of rides to no where. I hope something changes soon
Old 09-09-2014, 01:50 PM
with that then you must go to a GM dealership and have them re-flash your PCM.
if they cannot re-flash the PCM then this should explain why its not ready.
the ready state is a function of the PCM programing..could be damaged.
post back whats up this is weird stuff..
