Old 06-25-2014, 03:08 PM
firun firun is offline
Re: Toyota Celica GT-Four Monte Carlo'93 – full-open (ModellingMaster/Tamiya)
Phil, it's not late to fix this issue with fuel tank :-) But I almost broke my neck trying to find on Facebook photo you described... Could you please share a link to a post with this fuel tank operation? Thanks!
Btw, here are working hinges for doors and bootlid:
My kits collection.
Old 06-25-2014, 03:25 PM
rallymaster's Avatar
Oh sorry, it's not on Facebook but here on AF.
http://www.automotiveforums.com/vbulletin/showthread.php?t=1069812&page=9
Phil
Old 06-26-2014, 04:20 PM
Thanks Phil!
I've took a saw in my hands and started cutting here and there:
Waiting till the glue stones and will continue fuel tank business. The floor will be also leveled with epoxy.
My kits collection.
Old 06-27-2014, 03:11 PM
Continuing Celica plastic surgery – made a sketch of authentic door cards:
Now need to precisely cut plastic and make from it the door card's details.
Btw, the fuel tank is done in large – need to add detailing and remove some scratches from it.
My kits collection.
Old 06-28-2014, 04:40 AM
Naray Naray is offline
Fantastic Job Firun!!! Thanks for sharing your progress.
Could you explain the way you use to make the hinges?? I will like to open some models but i don΄t have the "Know how"....
Thank you in advnace
Naray
Old 06-28-2014, 05:13 AM
Naray, thanks for your kind words!
Making hinges is simple as 1-2-3 :-) All you need is paper clip, pliers, plastic rod and some epoxy putty.
With experience the process will take about 5-10 minutes.
First, I drill through hole in plastic rod – I attach this rod to the doors as it works like rotation axis. You may see the rods attached to doors on picture in my previous post.
Then I take paper clip and bend it with pliers in 4 points, if i'm not mistaken. Unfortunately I don't have pictures of bended paper clip, but you can catch the idea in my previous posts with pictures of door sills.
Then I check how the hinge works with door – put the hinge into the drilled rod. And after that I put the door with hinge into the door sill and fix it with masking tape. From the inside part of front fender in place where the hinge is located I put epoxy putty to fix it there permamently. In several hours I have working opening and detachable doors.
Sorry if this instruction is quite vague, but if you have any questions - feel free to ask!
By the way, i've read a lot of instructions for door hinges in magazines and forums, and they were pretty difficult in my opinion. This way of making hinges is easier I suppose.
My kits collection.
Old 06-28-2014, 03:42 PM
I've decided to build this model in agile mode – fast and precise, so every day I plan to have some work with model.
Today i've finished with fuel tank and door interiors:
I think that they are ready for a primer coat.
My kits collection.
Old 06-29-2014, 08:02 PM
heyes57's Avatar
heyes57 heyes57 is offline
Excellent job so far, I'm watching with great interest. I've just trolled though your thread and I can't see that anyone has directed you to this website, full of great detail that could help you enormously.....
classicrallymodels.piczo.com give it a try as it's helped my out a great deal.
Cheers Rick H
Australia
Old 06-30-2014, 06:39 AM
Cheers Rick H
Australia
Rick, If nobody didn't it's simply because many of the pics visible there are pure fantasy from rebuilt cars totally inacurate or also some references are false !!
just take a look at the 205T16 pics, mix of evo1, street or privateer one (linked as evo1), fantasy rebuilt evo2...
same for example for Maxi 5 turbo, which is in fact a 5 turbo with a maxi body...
these references can really be misleading if you expect accuracy and it's not so good modeling references IMHO.
Phil
Old 06-30-2014, 01:51 PM
zim produc zim produc is offline
Supebe work
Zim
Old 06-30-2014, 01:53 PM
heyes57's Avatar
Thanks for the heads-up Phil, didn't realise they weren't 100% accurate. Keep up the good work anyway and I'll continue to watch your progress.
Rick H
Old 06-30-2014, 02:15 PM
Rick H
You're welcome.
just want to add that if you can sort out what is original pics and what is not, the ones appearing accurate to original event cars are great reference though !
Phil
Old 06-30-2014, 04:34 PM
Done new fitment for underbody:
Here is rough draft of engine:
Cut the front air ducts:
My kits collection.
Old 06-30-2014, 04:55 PM
Fitment is perfect after your modifications.
engine coming, Mmm... Can't wait !
Phil
Old 07-02-2014, 03:06 PM
Sorry, long time – no update from me. Here we have our Celica in 1st coat of grey primer:
Add some putty and several hours and we are ready for 2nd coat of grey primer.
My kits collection.
