#16
Yes, ive seen one in real life.
Derek:word..im debating //Penner\\ : i'm a master debater Derek:well youve had a few more years experience than i Derek: Haha AF Sig Material |
#17
A 20B does the one thing to the car that a V8 conversion doesn't: messes up the balance of the car. And it's still unuseable on the street over 500 hp...
I've owned over a hundred cars in the last 40 years. What was I thinking? ![]() 2013 MINI JCW Roadster 2023 Chevy Bolt |
#18
GImme a JC Cosmos, and a FC transmission
#20
I wish I could get a decent JC Cosmo here! Absolutely one of my favorite coupes on the planet. 20B turbo in a beatuful body. Yummm!
#21
can i swap a rx-7 motor into my mazda b2200?
#22
#23
is there anywhere that sells the Renesis engine besides mazda sealers..and a Renesis would be nice in a FC3S...i would take one over a 240sx
See MORON HERE NISMO - Nissan Motorsports HOMO - Honda Motorsports IMHOIDTWSATFR....Crew # 00 Motherƒû¢l< the police :twoguns:
#24
Best RX-7 engine
I do think the Renesis needs more trial, more road time, especially if modifying. But, it's mostly proven, and new exhaust porting is superior except for extra heating of the block.
A journalist [not coolant/lube journals, but literature ] stated the exhaust is cooler this way, but I don't want it, I want it hot and direct for a turbo. The side-housing exhaust is helping hold the bang longer and seep an exit slower than the earlier peripheral-port exhaust. Both the intake and exhaust ports of the renesis ask for mild port rounding and a higher rpm limit, so expect >300 hp NA at high RPM, but we're talking about peak horsepower on a >8krpm engine, and power is a product of ignition frequency. Double the rpm, and get a theoretical 600 hp.I think the renesis's exhaust porting to the side of the rotor, having it snake through more metal before a manifold, is great for non-boost, but a mistake for pumping a turbo. This is a great engine to keep non-turbo. I'm not going to talk about a super-boosted 20b that pings/detonates at 105 octane with water fogger, with drastic low-rpm ignition retard, with a 1500 ft-lb clutch, at 105 octane, that trashes composite axles and differentials/transaxles for breakfast. Oops -- just did. Without engine bay modification for a 20b, variants of the 13B are satisfying. But this is funny looking squirrel: http://media.car-videos.com/videos/m..._RX-3_20B.mpeg I'm a happy TII owner. I use a separate Audi boinger for daily grind. The RX-8 chassis greatly out-classes in rigidity. The body aesthetics and the novelty rear doors don't encourage me. If the RX-8 were maybe the price of a used FD series, hmmmm.... Yet, lately I've have Porsche turbo on the mind. "best" is relative to application. |
#26
Re: Best RX-7 engine
Yay. its another Twin Turbo. I think everybody should just buy PORSCHES.
911 Super Targa RSR [Dual Flow Intake][Twin Turbo][Larger List to Come] |
#27
Re: RX-7 Engine
Twin scroll in designs I've seen, are only a secondary set of impeller blades, each a companion with primaries, without congesting the intake with multiple leading edges of blades; it steps the secondary set below the primary, keeping a good open cross-section. This helps grab new air, trap, and maintain boost compression at the spool-wheel perimeter. An example of weakening the principle -- reduce the quantity of impeller blades, say to 2, and do not increase spool rpm, do not increase blade pitch, and do not lengthen the blade path, do not increase spool diameter, the result is lower boost. However, at that lower boost, e.g., few ounces, the spool efficiency is high from lower impeller drag. [edited, I babbled even more] Blades congest the intake. The secondary blades fill-in the wide gaps between the trailing primary blades. Whatever is chosen, it's used to help scoup and hold the compressed air (a fluid). Last edited by jhillyer; 11-08-2003 at 03:46 PM. |
#28
Re: RX-7 Engine
Enthusiast conversions. A small v8 350 has been done for similar cost. The 350 has cheaper and highly available parts in the west. I'm amazed sweaty guys in t-shirts, hitting the bong ever 5 in Puerto Rico get a 20b to run 9 seconds for under US$1500. I would not expect a rebuilt 350 to match a rebuilt 20b in a rigorous cross-country endurance race. The Edelbrock Performer EGR 8.5:1 provides a nice 310hp and 375ft/lb, as a long block with ignition, but nothing else. Cost of engine: US$4,970 I've read a new 20b is a rare commodity and has a disgustingly inflated price of US$20k. The do-it-yourself method is getting the longer 20b crank and stacking another rotor. So, the 350 gives great performance, but not the same dynamics as the rotary. The highly tuned version of this Edel' 350, ~US$9,000, is ~425hp, and nearly at its absolute ceiling for power and torque for it's internals. Rolloff of torque and flattened power are at 5000 rpm. This is package almost as throttle responsive as the 20b. Go 6 months or 100 hours in this 350 without precision valve tuning (not in my budget, and multiple re-visits), and you're cranking drops <400hp. I think the 20b conversion is for the guys that have their investment manager's phone number in redial. But, I wanted to do it last year. I drive an Audi boinger and Mazda turbo wobbler. I can budget about $5k a year on car parts without thinking I'll live my geezer years in unhealthy poverty and isolation, but the 20b is far from a sensible conversion for the street, for me. The Renesis mounted into an earlier generation would be a nice trick, and for boost: a simple centrifugal supercharger to avoid effort of building in a turbo, when cost matters. ---edit--- Oh, fine kit: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2441694621 --edit 7/9-- Courtesy AtkinsRotary.com, single turbo 20b performance, nice thrust by 3.5krpm: http://www.atkinsrotary.com/3rotorinfo.htm Last edited by jhillyer; 11-09-2003 at 03:39 PM. |
#29
http://www.daltonautomotive.com/html/pricelist.htm
Need I say more? possibly... for those of you lazy people out there they're selling 20B's for $4995 AUD *knows where he's shopping*
#30
The love of the FD3
Even Nitrous Express didnt want to go with the cosmos engine. They had bought one, but, due to the hard work and amount of money it would take to get the frickin thing street legal and driveable period, it would have been too much trouble.Personally i would love to do the whole conversion thing, but i think id agree with the multi-million dollar company and just make the FD3 a bad a$$ ride with a massive turbo and all the other goodies. But thats just me dealin with what lil money i got, but believe me, if i had the money, Id do it.
V-Spec Man without a cause |
