Originally Posted by j cAT
the computer .......gauge is a slave .. pcm is the boss !
the evap system does not use the sender. the in tank pressure sensor does the evap reporting to the computer.
The readiness monitor supposedly requires the fuel to be at a certain level, or it won't set. I could not get it to set with the old worn out sender that would never stay in the middle range (I tried for days), but with a new sender it was set and ready in just a few miles. This is what leads me to believe the computer (PCM, ECM, BCM, whichever it is) is getting a correct reading from the sender, and the problem lies beyond the computer (wiring to the cluster, or the cluster itself). Is there any way to see what the computer is reading for fuel level to verify any of this?
Originally Posted by DeltaP
Thanks J cAT and Tech II. Good info on testing. But it just struck me funny when Mattyp6 said " I just picked up a new gauge cluster from the junkyard".
Hah yeah, good point. It was so cheap compared to what I found online, that I had to grab it whether or not I need it. I'm sure it's just fine.
