Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 11-14-2001, 12:58 AM
YCEE YCEE is offline
Hey guys out there who encounter pinging, in which gear WOT do you suffer most pinging? Did you monitor the EGT too? If yes, at what temp?
Old 11-14-2001, 04:22 AM
zapf zapf is offline
Try running your car on BP 98 and also Mobil 98, some people / cars like one better than the other. You'll find also that not only high boost creates detonation. With older cars, they can have a fuel pump on the way out and not having enought flow or fuel pressure. Hence the car runs lean and can detonate even at slightly higher than standard boost.
Cheers
Zapf
Old 11-14-2001, 06:24 AM
meggala meggala is offline
and don't worry about advancing the timing drive the car on optimax or synergy and get used to it. you have a fast car already in a month or so then look at what you can do.
meggala
check out my site
http://www.meggala.com
jdm info and drifting stuff
nissan cefiro a31 fitted with
sr20 and trust t518z turbo.
13.3 @ 105.69 mph 2.069 60'
full street trim
Old 11-14-2001, 07:32 AM
matlowth matlowth is offline
Send a message via ICQ to matlowth
If my car pings, it'll usually do it in a higher gear 3rd some times, mainly 4th (usually after a bad batch of fuel too), and usually after running it through the gears. It's not loud enough to hear, but the pfc makes the check engine light flash and knock gets above 60.
If your car's pinging, I'd imagine your EGT would go thru the roof? I haven't got a exhaust temp guage on my car to confirm this tho?
matt
Old 11-14-2001, 02:06 PM
[TWUBLE]'s Avatar
[TWUBLE] [TWUBLE] is offline
meggala
are you talking about my car? or someone elses...
I dont think id advance the timing anyway... im not that clued up and would rather leave it to someone who knows what they are doing so i dont fuck up the car
Proud to be a member of the AF Kiwi Krew!
1 life, 1 licence, 1 day, Save it for the strip...
You cant begin to consider the palpable hate in the air when your near. - s|ipkn0t
Why do I have a conscious. All it does is fuck with me! - k0Rn
Old 11-14-2001, 02:13 PM
Cheers
Zapf
Is the octane rating of BP98 and Mobil98 98 octane? Right now I'm using Shell V-Power which is 97 octane, does it make real difference with 98 octane?
Old 11-14-2001, 04:20 PM
blacksky33 blacksky33 is offline
Send a message via ICQ to blacksky33
before i had my intercooler fitted i had some pinging after parking the car for 5-10 min on a hot day then driving it a little hard i put it down to heat soaked pipes :flash: :flash:
Old 11-14-2001, 06:42 PM
[TWUBLE]'s Avatar
oh ok... haha all i have to say is you have a SERIOUSLY cool sig man!
Old 11-14-2001, 07:51 PM
Ethan_R33 Ethan_R33 is offline
My boost is only somewhere between 10-12psi (bout 6 1/2 ish on the standard boost guage).
hey, how did you get your boost up to that? Just an aftermarket boost controller??
Old 11-14-2001, 08:05 PM
[TWUBLE]'s Avatar
nah when i bought the car it had a 3" exhaust system and a k&n m's filter.... im thinking my boost is actually at about 13.5 not 10-12..... i need to get a boost controller tho....
what is your car boosting?
Old 11-14-2001, 08:17 PM
geez if you have 12 or over thats pretty high????
mines got big exhaust, intercooler and pod filter and only has standard boost (7psi) it only goes about half way up the standard boost gauge. Which is roughly 7psi.
Howcome yours is so high?? i mean thats not a bad thing, i want mine that high too!!!!!!!
Old 11-14-2001, 08:22 PM
[TWUBLE]'s Avatar
if yours is going half way on the standard boost guage by chance its probably higher than 7psi.... check out the conversion tables in the performance section on how to read the standard boost guage.
Also what kind of exhaust have you got...
you have a front mount? lucky! :P
Old 11-14-2001, 08:39 PM
yeah it wouldnt be much more than 7psi though
i have a HKS super dragger 4 inch straight through with 5 inch tip. also HKS dump pipe with separate wastegate pipe.
And also HKS intercooler.
So yes a lot of nice HKS stuff.
I got it all when i imported it
Old 11-14-2001, 08:43 PM
[TWUBLE]'s Avatar
4" pipe is probably a bit excessive. Mine has a 3" racing exhaust (tuned turbo down pipes) GAB adjustables with HKS springs and a K&N filter...
Old 11-14-2001, 09:34 PM
nah 4 inch isnt too excessive. its perfect!!!!!!
Gives it a really low rumble and screams at high revs. Also is less restrictive so it is good for it. And i also have a blitz pod filter with cold air induction, and zeal suspension.
I just want more boost!!!!!!!!!!!!!:cry: :cry:
