Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-06-2003, 02:49 PM
CrazyFastTurbo CrazyFastTurbo is offline
Drag manifolds crack (have seen this quite often). Max-Rev manifolds don't and Max-Rev kits come with a lifetime warranty on manifold and downpipe.
Old 07-06-2003, 11:35 PM
edman24 edman24 is offline
Send a message via AIM to edman24
well i dont believe that over 100hp to the wheels bs. those companies pump up the actual gains so much its hard to tell if its true or not. but that is definitely not true. there is no way that kit on your car would produce over 100 extra hp at the wheels and still make more then a few dyno runs without blowing. id put money on that.
I feel bad for those who pay twice as much as i did for my car and still lose to me. The sorrow in their face is enough to bring me to tears.
Old 07-07-2003, 01:05 AM
rygan21 rygan21 is offline
hey since we have so many knowlegable (sp) people here mind if i ask a few questions? ok so if i get a turbo what kind of gas should i get? and how often should i get tune ups? is this enough for a daily driver
94 civic ex coupe w 98 acura ls engine (b18b)
-rev hard turbo kit
-spark plugs
-greddy oil cooler
-greddy cat back exhaust
-apexi type r boost contoller
-apex turbo timer
-fluidyne radiator
-(do i need injectors?)
should this last me at 7-9psi for 20,000-25,000 miles a year????? thanks for your opinion
also what kind of hp/quarter mile times should i expect??
Old 07-07-2003, 10:34 AM
if you keep your boost that low and dont get too happy with it it will last you a long time. you can only use the highest octane pump gas available. im in cali so its 91 here which is crap but anyways. and also tune ups. i dont like people referring to repairs as tune ups. what does tune up refer to? what does it include? basically when you do that setup just keep up with the oil changes, filter changes, coolant, and everything else just like you would if you wanted your engine to run at its best. im not positive on your 1/4 times but it should be in the 13's.
Old 07-07-2003, 03:43 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Tune up is in the ignition. Spark plugs, check coil, wires, cap+rotor, etc. Oh and air filter is sometimes included but not always. Oil change is usually not included, therefore you have to say you need a tune up and oil change. Changing the oil filter usually does go along with oil change though.
Old 07-07-2003, 11:51 PM
anything else to help logevity? like is their anything i should add to that list? maybe injectors..?? i dont what do you guys think is that a pretty complete list ??
Old 07-12-2003, 09:38 PM
bump..so that list is pretty complete
Old 07-13-2003, 07:59 AM
smokey8890's Avatar
smokey8890 smokey8890 is offline
lower compression pistons, turbo timer, and constant checkup of your car will make sure everything last. turbo timer is a simple device that lets your car idle for a few minute after you take the key out. why? after driving around your turbo need to cool down. When you shut the car off the oil pump stops pumping to your turbo. And for all you automatics out there you might want to invest in something like a msd btm. Unlike manual transmissions automatic's do not have control of there rpm. Over reving your stock internal will wear down things alot faster. quick fix will be to buy a rev control ,forged rods, or atleast get it peen shot and polish. MSD also have a 6 BTM which have a rev control, retard timing conrol, and gives a high discharge for preventing dentonation. don't try to cut coners whenyou invest so much into your engine. if your gonna do it. do it right.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
