Old 05-28-2013, 07:00 AM
Autovic Autovic is offline
Re: Few codes - Which one to fix?
Originally Posted by 12Ounce View Post
Well, I think you may not reading the repair book correctly ... and you need some other people to talk to, at least about auto details.
Why don't you just count the sensors? I assure there are more than two ... unless someone has installed a 4 cylinder engine in your Windstar. And then you truly have a museum piece!
Well I checked again, there might be four, I remember two and I did see one further down back to the car. What I was going by was this picture (image 5.4) from the repair manual, which I uploaded.
So which one of these do you think I should check or exchange. I know the front one is ok, but the other three, which one is bank 1 sensor 2, I don't know what that means.
Old 05-28-2013, 07:57 AM
12Ounce 12Ounce is offline
Take a moment and go back and read each post that folks have written to you ... slowly, word-by-word. I think you learn more if you just slow down a bit and carefully read and listen.
Old 06-11-2013, 11:10 AM
Ok, I replaced the third one on Sunday (this one really looked messed up, the other ones just little scratches here and there).
The check engine light went off Monday and it has since been off, but I still canćt pass because the mechanic hooked up the reader and it has two flashing icons (C for converter and another one), he says that I can't pass unless at least one of them shuts off.
I'm going to drive the car this week and go back to see if one of those icons will shut off, so that I can proceed. If that doesn't happen, I will request a waiver from the motor vehicles department to pass emissions.
I just wrote this so that people in a similar situation might find this helpful.
Old 06-11-2013, 01:57 PM
As has already been written, different states and jurisdictions treat the matter differently. I believe my state, Georgia, only concerns itself with the emissions (OBDII) codes ...never the drivetrain codes. (I'm guessing that what the "C" code is ... a code concerning the transmission converter slipping or not locking-up ... but who knows?)
I would suggest you go to an AutoZone and see what they read.
