Old 03-13-2013, 01:03 PM
hurstg01's Avatar
hurstg01 hurstg01 is offline
Re: Wheel dimension for McLaren F1 GTR?
Instagram/
Old 03-13-2013, 01:11 PM
mclarenf1papa mclarenf1papa is offline
What about the Longtail GTR's wheel sizes? Anyone know?
Old 03-13-2013, 03:41 PM
Peloton25's Avatar
McLaren Fanatic
I haven't had a chance to look - but might have a source. I will respond if I find them for you.
>8^)
ER
The Following User Says Thank You to Peloton25 For This Useful Post:
mclarenf1papa (03-13-2013)
  #19
Old 03-13-2013, 07:03 PM
I found this: http://www.automobile-catalog.com/ti...long_tail.html
Don't know if it's accurate or not, but can someone put the sizes into a different format? I don't understand the one it's in...
Old 03-13-2013, 07:21 PM
carbuilder2002 carbuilder2002 is offline
Go on Greg you know you want them lol
Old 03-13-2013, 07:49 PM
Peloton25's Avatar
McLaren Fanatic
The wheel sizes supplied via that link are essentially the same as what I provided for the LM/GTR wheel, just written a different way. I would not count on that being 100% correct for the longtails.
>8^)
ER
  #22
Old 03-13-2013, 08:40 PM
>8^)
ER
That's what I was thinking...(about them not being accurate) Do you have any other sources than the one I provided? Thanks.
Old 03-13-2013, 11:39 PM
I think it might be something like:
270/35-R18
345/35-R18
Old 03-14-2013, 02:11 AM
Peloton25's Avatar
McLaren Fanatic
papa - Did you care about the wheel size or the tire size? Because you asked about wheels which are the metal part, now you are talking about the rubber part...
Anyway, I found my 1997 Gulf GTR press kit and the wheel dimensions listed within are indeed a match for the sizes already mentioned. I'll look for secondary confirmation of that from another source as well. There is no measurement supplied for the tires.
Their slick tires would not be sized like a traditional road tire - the sidewall measurement of a slick is not a ratio of the width, but rather their actual measure of their height in millimeters.
>8^)
ER
mclarenf1papa (03-14-2013)
  #25
Old 03-14-2013, 02:47 AM
In addition to that it is possible to fit at least 3 different width of tyre to a given rim width with the difference being taken up by slight deformation of the sidewalls.
Old 03-14-2013, 06:40 AM
Kapten_Brynt's Avatar
Kapten_Brynt Kapten_Brynt is offline
thanks you all for the response!
i have contacted MSO and we'll see how this pans out
Kapten Brynt: Licensed Nürburgring-fanatic
Old 03-14-2013, 07:05 AM
Le Man's Avatar
Le Man Le Man is offline
97 GTR Tyre data,
Michelin,
Front :- 27 / 65 - 18 .......... Actual dia listed 646mm
Rear :- 30 / 70 - 18 ............ " " " 710mm
Tyre diameter and rolling circumference will vary, due to tyre wear and more important for the rears, wheel rpm at high speed increasing tyre dia which naturally effects the calculated gearing of the car.
The Following User Says Thank You to Le Man For This Useful Post:
  #28
Old 03-14-2013, 07:21 AM
Good luck I am sure you will get a good price for them assuming they are sound and not defective.
Old 03-14-2013, 12:00 PM
Thanks guys
Old 03-14-2013, 12:52 PM
hurstg01's Avatar
Instagram/
