#16
Re: Multiple DTCs, erratic idle and loud pinging
The intake manifold on this engine has three major components:
1. The plastic upper, held in place by 14, or so, bolts. (On many early engines, this part had a removable inner piece.) 2. The plastic spacer. This is the piece that receives inlet air from the filter through the throttle body. Held in place by 8 complex screws that have a rubber component/seal. It is these screws that have failed, due to oil exposure, on early engines. This is the screw that changed from black-to-green rubber when it was up-graded. 3. The aluminum lower. (The spacer is mounted to the lower.) The lower is a rather complex piece. Not only does it pass air, and EGR gas, to the cyls; it closes off the top of the block ....and passes coolant to the heads. The swirl control ... or as Ford calls it: the intake-runner-control .... is all part of the lower. The lower is mounted to both heads and the block ... so there are two gaskets for the heads, and two shaped end seals for the block. Every thing is fairly easy for the DIY ... until you get down to the aluminum lower. I would try to avoid disturbing this part unless absolutely necessary. Then I would not know who to trust to install it properly.... other than myself, and I'm not too sure of him! |
#17
code 171-174 are all common code for thr intake gasketand gromit vac leak lean bank look it up on the forum coil packs go bad too i replaced my wifes 120000 pull the coil out look on the bottom you can see the crack if there bad all these are not that hard to do
#18
Let us know how it turns out. I really hope it's just a cheap fix! You should be able to get the IMRC linkages from junkyards.
Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
#19
Dear All,
In essence if someone buys a ford car, always be afraid of something failing or breaking because of poor material which are not oil or heat resistance, poor design which will generate heat and no space to work. I had been using Japani cars almost never went to workshop for breakage, only for failing some plugs at almost predictable time. My friends have European cars best in strength and designs; almost in 6 six years I have never known anyone, going to workshops except, for change for oil, tires, break pads, etc. I have this white elephant since 4 years to years for workshops with a lot of money. If runs good afraid of some thing failing or breaking period of satisfaction only two or one month |
#20
I have had my '99 for near 13 years now. Thanks to this forum and my shop manuals, I have been able to repair much that has failed. Now I feel like I can fix anything that goes wrong. This makes it a pretty reliable vehicle for use in North America.
However, even with all this experience and the on-line help .... if I were suddenly shipped out to another country around the globe, the Winny would not be welcomed to go along. If I could not drive a short distance to get the many repair parts it needs, (as I now can) I would not have nearly as much faith in it. Good luck! |
#21
Thanks everyone for all the help and advice. I will see what the shop says in the morning. I really need to keep this thing running because it fits the whole family and my mother-in-law's wheelchair (it's a big van), but I'm seriously considering cutting my losses on this one. I am sick to death of constantly fixing things on my Windstar and am ready to give up. I know many of you feel the same way. |
#22
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal 2008 F150 FX4 5.4L V8 - Wintermobile 2000 Windstar SE 3.8L V6 - Beast of burden 1995 BMW 540i 4.0L V8 - Weirdest car ever owned |
#23
Oscar.
#24
And your local Ford mechanics are probably not familiar with the engine, making them more prone to make mistakes and still charge you a bundle.
#25
UPDATE: See below
I'm so far quite impressed with the place I chose to do the work. They tested and found out that the lower intake needs to be replaced, so I saw the partially cleaned lower intake out of the engine, in which the EGR ports were nearly completely blocked. That iso bolt job done at the dealership 90k miles ago apparently either didn't last this long, or they didn't pay too much attention to detail. When I get the van back tomorrow, it will have a new lower intake gasket, new isolator bolt grommets, clean EGR ports, new gaskets on the upper intake and spacer (and I guess the throttle body too), new injector o-rings, a B&G fuel flush service, and a coolant flush with a B&G service (suspended hardener for radiator pinholes and a 'water wetter'). It will also get another oil change with a new filter since there is apparently a TSB on Motorcraft oil filters for this vehicle. Anyone know about this one? Precisely the reason I bought another one two years ago when my first one was wrecked. |
#26
Oil pooling on top of the intake spacer is quite normal for this engine. It is oil that came out of the crankcase via the PCV system. In most engines this oil will harmlessly find its way into the combustion chambers and will be burned, actually aiding upper cylinder lubrication in the process. In our 3.8's however, the oil does two things bad ...(1) It drips, thru poor fitting seams, from the spacer down onto the EGR jets, where it meets hot exhaust gas and forms clogging build-up .... and (2) it pools against the rubber of the isolator bolts and tends to soften the rubber, especially the early design isolator bolts. All engines with a PCV system will have some crankcase oil injected into the inlet air stream. As the engine wears, depending on the maintenance program, this stream of oil will increase with increasing piston blow-by. |
#27
So anyway, my van is back and after changing the coil, plugs and wires, it runs terrifically now. So much better that I may actually keep the van. I did the rear plugs and wires last time when I had the upper intake shell off for the iso bolt job, so this time it was quite a pain in the neck (and arms and shoulders). What a colossal PITA. So glad it's done and I likely won't have to mess with it again before the van dies. 172k miles and counting. Thanks guys for all of your help and advice. |
#28
Glad it's all good now!
I remember the original bolts being black, the later improved ones that I have been using are green ... I don't know about blue ones. |
