Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 08-11-2003, 03:01 PM
killasoundz killasoundz is offline
yeah but if hes dumb enough to think he has a DOHC 22RE he might not notice that he has 2 extra cylinders.
1979 celica GT 5speed
ww.classic-celica.com
Old 08-12-2003, 03:11 AM
Antyoo Antyoo is offline
his car easily does 14's according to him, and all he has is a home made CAI, removed cat, and a header.
and oh yeah, he has a cracked block and messed up sport transmission.
Old 08-12-2003, 09:50 AM
if he had the 6mge then he would probably be able to run 14s pretty easy. they make about 190hp then if he had a CAI that would up it to about 195hp.
Old 08-12-2003, 03:31 PM
even if he did have a DOHC 22RE he still wouldnt be running 14s easily. maybe mid to high 16s. figure a stock 22RE in 95 was 95hp and 136lbft of torque. with a DOHC head the 4age of that time made 128hp. to lets say with double the capacity the engine makes 150hp and about 145lb ft of torque with slightly higher revs in the 6500rpm range. a header and CAI might get him up to 160hp because of the limited perfermance potential of the 22RE computer. even the 22RTE computer has its limits with boost. he wouldnt be running 14s maybe high 15s but 14s easily is a joke.
Old 08-31-2003, 06:28 PM
Daisrocks Daisrocks is offline
Send a message via ICQ to Daisrocks
Oh my, this has got to be the funniest thread I have read in a long time. Thanks all for making my day at work go faster
But I think you have to be a very special kind of stupid if you can't count how many cams you have, so lets assume that "sk8nb" does have 2 cams and not some very serious counting disorder, then he must just have a different engine from the one he thinks. Problem solved.
Be fast, be vigilant, behave.
Old 08-31-2003, 07:04 PM
sk8nbroslofski sk8nbroslofski is offline
Send a message via AIM to sk8nbroslofski
well here i am to put my foot in my mouth. its SOHC. ive just smoked myself stupid over the past couple of years. anyway, i admit it, im dumb. question for yoy guys, would it be possible to get a supra 5mge into my celica. i blew an exhaust valve and its gonna be a bitch to fix. i can get my supra engine for 200 bux, and get it put in for some more money. but the question is, am i gonna have to fuck with the engine bay to get it put in?
Old 09-06-2003, 11:20 AM
itll bolt in might have to move radiator under support but it bolts up otherwise. check out toysport they have a 7mgte in a convertible. and a friend of mine has a 7mge in a 77 liftback and i test fitted a 7mgte in my car and it fit right in.
Old 09-06-2003, 02:21 PM
so far weve figured, were gonna have to swap the k support (whatever the part with the motor mounts is called, thats what he called it.) and cut a little bit out of the front end. also gonna have to lift a spot on the hood. sound about right?
Old 09-13-2003, 01:49 PM
shouldnt have to cut the crossmember. just get some 5M engine mounts. and the trans and bellhousing from an 82-86 (not 86.5) supra and you're set. might have to cut the core support but you should be able to just retro fit the radiator under neath the support.
Old 09-13-2003, 09:29 PM
well, with a few drugs and the grace of god, i think this will work. everyone keep your fingers crossed.
