Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 06-13-2003, 08:22 AM
Scott 02's Avatar
Scott 02 Scott 02 is offline
Banned
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
you want to know my advice? ok all he really needs to do if he wants a cat-back exhaust for half the price, then he needs to buy a Flowmaster Y-pipe if he wants to do it this way. That costs about $40 then 2 Thrush Turbo Mufflers for $50 Thats FOR TWO! and if his existing exhaust has a resonator, remove it and replace with piping. $12 This job can be done at around $115. Don't wast your money on expensive mufflers or cat-backes. I have had over 25 brands of mufflers tested and amazingly the best on i have seen as far as making awsome airflow and just enough backpressure is the dynomax's mufflers which also make thrush.
Old 06-13-2003, 08:23 AM
Scott 02's Avatar
Banned
If you want to run duels straight back off the mainifolds, then you will have to take it to a muffler shop and have them do it, unless you have your own pipe bender, but i would recomend a muffler shop. Then again, don't spend alot of your mony on mufflers that you are paying an extra 30-60 bucks just because a name like Borla or Flowmaster is on it.
Old 06-13-2003, 10:32 AM
CougarSVT CougarSVT is offline
Send a message via AIM to CougarSVT
Your from Ohio heh? Where at in Ohio? If your good you can make your own exhaust without a pipe bender, you can also go side pipe if you want. Pretty cool to see a side piped Cougar! If you go true dual make sure the diameter is under 2"(od)...or you will loose way to much back pressure. Good luck!
Dealer for Turbonetics products...cant beat our price!
Dealer for SCT......fine tuning software
T3/T4e, super series, Hybrid, stage III Turbine $650.00+tax
T3/T4e Ball Bearing, Hybrid stage III Turbine $1,050.00 +tax
Turbonetics EVO wastegates...$200.00!!!
Turbonetics Raptor Bypass Valves
Turbonetics Turbo kits for Civic's, Preludes, GSR's for $2,999.00!!
Spearco IC's from $225.000
PHONE #: 937-336-1462 ask for Stephen N Brown
********HAPPY HOLIDAYS********
Old 06-13-2003, 10:34 AM
Scott 02's Avatar
Banned
lol side pipe. i have done that once to a 1987 1500 series truck 350. threw some glassbacks on with turn downs that we actually had turned out to the sides. LOUD AS HELL!
Old 06-21-2003, 09:28 PM
The Cougar looks good side piped through ground effects. Just like the newer Mustang side pipes. Sides pipes can actually give you more hp's...not alot but usually more than rear pipes.
