#16
Re: removing AC
tomorrow im going to try putting on belt conditioner and see if it keeps squealing
my dad seems to think it might be a bearing gone bad in the a/c motor... also wondering about using defrost if i remove the belt and dont replace it.... i know wont have a/c but i need heat and defrost for the winter... |
#17
Re: removing AC
Re: removing AC
replaced the belt today and the noise is still there....auto shop guy thinks its the bearing?
any more ideas or tests i can run? |
#19
Re: removing AC
the bearing will always make noise ac on or off . if the noise is only when the ac is on then you may require the clutch gap to be adjusted. you will need a special tool to do this. with the gap too wide this causes the noise. the ac compressor bearing when it fails should cause a loss of refrigerent rapidly. so if you get good cooling I would be surprised if the compressor is bad making the noise. check the ac pressures hi/low and also at what temp air is outside vehicle.... |
