Old 06-23-2012, 09:11 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 99 lumina transmission problems
Not up on tranny scan diagnostics. What does fluid volume mean to the scanner, exactly...? I mean what value is it actually reading?
What happens to the fluid temp when it quits working right?
I'd still bet it's blowing off hydro pressure somewhere once warmed up...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
The Following User Says Thank You to jeffcoslacker For This Useful Post:
dimperdoo (06-28-2012)
  #17
Old 06-28-2012, 05:34 PM
dimperdoo dimperdoo is offline
I wonder these things as well - the scanner just says "fluid volume" and gives a # -makes it kind of difficult to discuss because you want to say GPM or LPM or something not just "2.4"
It stays the same once it comes to temp - but, I wouldn't be surprised if reaching temp is when the tranny slips... I don't remember the values -may have to check again once I get home
yeah I'm thinking that too - still haven't dropped the pan since I'm working on my blazer and my cougar currently... lumina is the next project
Old 08-02-2012, 01:01 PM
pairof97blazers pairof97blazers is offline
just wanted to point out, i swapped the filter, and it has done ok for a w hile, but its getting worse. there were a lot of filings in the pan when i dropped it as well. I have found a trans i can afford and will be doing the swap this week. any hints?
Old 08-05-2012, 01:17 PM
trannyman52 trannyman52 is offline
4t60E ,,,4t65E ,,,transmission pans are very shallow,,,over-fill trans about a quart,,takes trans starving for oil out of the question,,,will not hurt trans......P.S.,,,,scanner will not tell you if hard parts are broken in transmission,,,more than likely foreward clutch seals ka-poot,,,,,if reverse engages ok,,,,then fwd clutch is the problem......
Old 08-05-2012, 02:59 PM
i was always told if you overfill the trans you risk blowing seals... But i do like the idea
1996 Chevy Lumina ignition problem! RedAzureSkye Lumina 2 05-29-2011 08:48 AM
98 Lumina Transmission Problem... MSimpson Lumina 5 10-09-2007 06:30 AM
1991 lumina Transmission problems?? bobbarker123 Lumina 1 09-16-2007 02:06 AM
97 Lumina Transmission problem frank schaefer Lumina 4 11-04-2005 07:02 PM
