Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 04-07-2012, 06:35 PM   #16
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
Re: Cannot start my 94 xj...
So did you get it started?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
Old 04-07-2012, 10:36 PM   #17
fiq
Originally Posted by fredjacksonsan View Post
There are 2 different parts for the 1994 XJ. If you send me your VIN (vehicle identification number) I can find out about the correct part.
this my chasis no:XJM000018
engine no:269366
year:1993
2.5L
hope u can help me..
fiq is offline   Reply With Quote
Old 04-08-2012, 12:14 PM   #18
fredjacksonsan
Do you have manual or automatic transmission?
Old 04-08-2012, 10:25 PM   #19
fiq
manual transmisioon..i still dont have the part..
Old 04-11-2012, 07:19 PM   #20
fredjacksonsan
I will post the part information tomorrow.
Old 04-12-2012, 08:07 PM   #21
fredjacksonsan
The part is $66 US and $15 to ship to you. If you would still want me to purchase it for you send me a private message.
Old 04-12-2012, 09:08 PM   #22
fiq
1-56026882
can dis part fit my cherokee?
dis CPS for 4.0L cherokee..
Old 04-13-2012, 08:40 AM   #23
fredjacksonsan
Yes that is also the part for the 4.0. But I think they used the same one on both engines. I looked online and also went to the store and talked to the parts man.
Please look at this website:
http://shop.advanceautoparts.com/web...p2HomeClicked=
The site says that it will ship parts, but I don't know if they will ship outside the US. If they will ship to you, that is good. If they will not ship to you, I can buy and ship to you.
Old 04-14-2012, 10:47 AM   #24
fiq
thanx for the info..already got the part from local n luckily its MOPAr,,will update after fix the problem..thanx a lot..
Old 04-23-2012, 09:40 AM   #25
fiq
fred...i already plug the new CPS...but ist still not working..still crank but wont start....just tighten the battry cable..still wont..n i try the ignition trick n the pulse show 12, 55 code..what does it mean?n badly now i cant hear any sound from my fuel pump when i turn on my key...any suggestion?
Old 04-24-2012, 02:33 AM   #26
ricebike
12 = Battery Disconnected
55 = Completion Of Fault Code Display
did you check the fuses?
ricebike is offline   Reply With Quote
Old 04-24-2012, 08:50 PM   #27
fiq
completion of fault code display?what does it mean?which part shud i check?
any method to check the fuses?
how can i makesure which one -ve n +ve cable for the battry cnnection?
Old 04-25-2012, 01:52 AM   #28
ricebike
that means there were no trouble codes since the battery was disconnected...
you probably blew a fuse or fusible link somewhere when you tried to jump start the vehicle or when connecting the battery cables wrong
Old 04-25-2012, 11:31 AM   #29
fiq
thanx God, dis evening i just got it started...after change the fuse, blow the plug hole wif air cmpressor, its get started...but still got missfire, sound like sumting explode at exhaust n sumtime at the engine (dont know the exact part)..and the idle running annoying..like a timing problem.can u state any problem dat cause dat symtom?just change the new cps..help me..
Old 04-25-2012, 11:45 AM   #30
fredjacksonsan
How many km/mi since you changed the spark plugs? Also I think your year has a distributor cap and rotor. Those should all be changed every 48000km / 30000 miles. Worn spark plugs, cap, and rotor can cause rough running.
Also, inspect your spark plug wires; on a vehicle this old they may need to be replaced.
Suburban Cannot start!! flexxylexxy Suburban 4 09-05-2006 07:39 AM
Cannot start 1999 Lumina vt4000 Lumina 28 07-20-2006 03:39 PM
No electrical equipment working except headlight, cannot start the car nik_istinov General Discussion 3 01-05-2005 09:35 PM
Engine cannot start sometime and getting worst. tehskhg Escape | Maverick | Escape Hybrid 0 11-12-2004 07:17 PM
