Old 08-20-2011, 01:13 PM
98cavalier22 98cavalier22 is offline
Re: 98 cavalier 2.2 no power when accelerating and revs long through the gears.
Originally Posted by inafogg View Post
i've heard of intakes not aligning up when removing them for repairs.
i have not seen this, but evedently they were redrilling the manifold holes to realign.if you do a search you'll find your not the 1st this has happened to.
That's crazy. Aluminum is the best choice for manifolds for durability but plastic is simple cheap and does flow a lot nicer because of the lack of casting flaws... I suppose that after 200k miles it's done its duty. I've actually found a site selling what seemed to be a metal manifold for about $100 but I find that hard to believe as they should be more like $300.
Has anyone upgraded manifolds before?
Old 08-28-2011, 03:41 PM
So I finally got around to removing the intake from the car for a better inspection... (I was trying not to unplug all of the harness wires to reduce confusion later on with re-assembly)
This is what I found...
Uploaded with ImageShack.us
So you can tell the manifold is nice and warped... It's no wonder there was a huge vacuum leak! I wonder just how much dirt and crap this thing has sucked up because of it. It looks like it was the side closest to the EGR valve. I wouldn't be surprised if the EGR valve was slightly stuck open allowing some of the hot exhaust to go into the intake thus aiding with the warpage.
What do you guys think? I think if I get another one of these from the wreckers I won't be getting one in much better condition although I would hope that the gasket will actually fit lol...
I hope this helps someone else experiencing this kind of problem. The diagnosing and head banging weren't fun at all, although I do like a challenge (be careful what you wish for!)
Thanks again for the help everyone
Old 08-28-2011, 09:02 PM
I also have a 2002 pontiac sunfire with the 2.2 ecotec. barely 140,000km on the clock and the timing chain crapped out... Will the intake manifold bolt up? If it will then maybe I can rig something up because I really don't feel like spending anything on this heap of ****.
If you haven't already noticed, I'm a big fan of GM products...
1997 Chevy S10 2.2 Starts Then Dies Logan76 S-10 9 07-29-2010 03:44 PM
no start 95 cavalier 2.2 jeffyweasel Cavalier Problem Diagnosis 2 03-14-2009 06:12 PM
96 cavalier no power when accelerating justadumbgirl Cavalier Problem Diagnosis 2 05-02-2008 02:23 AM
Car Hesitates/Bucks when accelerating and switching gears. chubbybistro Sonata 4 05-07-2006 05:30 AM
