Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 09-04-2011, 01:09 PM
Werling Werling is offline
Re: Fender Flares
If you look at the first picture of the yellow car the vents should be on both sides of the hood where the # 15 is located.
Old 09-04-2011, 01:13 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Fender Flares
@ Werling....That would put the vent on either side of the radiator shroud. I don't think that would vent any of the radiator. If you layout the radiator on the hood the back side of the radiator is located beyond the center hood bulge roughly 6" +/-. So the vents need to be where you and I both placed the center pair of vents. The only thing I am considering is building the shroud to connect the radiator directly to the vented area.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 09-04-2011, 04:10 PM
NZGTRA17 NZGTRA17 is offline
Re: Fender Flares
Originally Posted by Werling View Post
In order to vent the air out of the radiator there should be an opening at the front lower portiion of the hood close to the point where the hood slides under the front bumper, some type of sheet metal or alum would do the trick it should go from the bottom of the rad. to the bottom side of the hood wherre the opening is located. Many race cars have this type of opening, look at a currrent GT-Ford for example or many of the Can Am cars or IMSA cars. Air coming into the engine compartment thur the radiator acts as a parachut, it needs to exit some where. Just my opinion.
Yes agree with above on the "parachute" comment. The air comes in through the radiator and hits the engine mass and slows as it looks for a way out. Idea is to dflect the air up just in front of the engine and out through the bonnet. This is normally via a large opening which is either completely open or has a large lovre set up (due volume of air).
The louvres you are fitting will do some of the job as they will relieve any high pressure areas resulting from the air flow slowing as it hits the engine mass.
I am going to look at this over the off season (April next year) and as part of fitting a flat bottom and Ford GT diffusers that I have already purchased.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 09-04-2011, 04:43 PM
Re: Fender Flares
Brian. You are right the openings need to be behind the radiator, I may attemp to build what I think would work so the air coming thur the radiator will just move up and out close to the front of the hood.
Old 09-04-2011, 04:48 PM
Re: Fender Flares
Brian & kel send me your emails address & I will send you pictures of what I am talking about.
Old 09-06-2011, 02:07 PM
eric1h eric1h is offline
Re: Fender Flares
thats where my vent is! :-D
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 09-06-2011, 02:25 PM
Re: Fender Flares
The Following User Says Thank You to eric1h For This Useful Post:
PanozDuke (11-10-2011)
  #23
Old 09-06-2011, 06:02 PM
Re: Fender Flares
Did the vent lower oil temps? Where did you get that vent?
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 09-07-2011, 08:23 AM
Re: Fender Flares
The vent is from a GT-500, I cut it to size(took about 6" out of the middle) Seems to have lowered oil temps, although I never ran TOO hot anyway, and the motor runs nice and cool, and cuts down on some of the hood buffeting.
Old 09-12-2011, 11:03 AM
Re: Fender Flares
I have the last set of virgin fender flares for sale, look like the pictures of Brian's call 619-559-0968 or werling @ aol.com to order
Old 09-12-2011, 03:23 PM
Re: Fender Flares
Wes, did you get a chance to measure any underbonnet pressures prior to selecting the location of the hood vents? I am looking at this mod prior to upcoming NZ Endurance champs and want to make sure pacement is optimal.
Post fitment could you discern any reduction in water or oil temps?
Thanks, Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 09-13-2011, 10:49 PM
Re: Fender Flares
I put the ventss where I though they would work best without any real research, I think they have help reduce temps but I did not due a before or after test to see the difference. One thing I can tell you is that the vents are real hot at the end of a 30 min. race.
Old 09-14-2011, 03:08 PM
Re: Fender Flares
Thanks for the feedback Wes.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 11-09-2011, 09:08 PM
Re: Fender Flares
Brian did you notice any difference with the hood events when you ran at Daytona? From the video it looks like your hood and windshield are not moving the way the did in previous videos. What is the verdict on the hood vents?
Old 11-10-2011, 07:17 AM
Re: Fender Flares
Well....Things are much more stable since I welded in 4 supports and made custom bent beefy "T" braces at three locations for the windshield. So that eliminated that issue. Since I am having overheating issues that are new I am not sure on the cooling properties of the vents. On the aero properties I would say absolutely. I was on the rev limiter much earlier than previously and my lap times dropped right away from my last time there in May. It was cooler so that will also help but I felt like I was getting to top speed much easier. Without data I cannot prove it but my seat of the pants has lead me this far so I think its calibrated :-)
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
70-78 Datsun Z IMSA Style Rear Fender Flares $85 OBO doggyollie Classifieds 1 04-27-2010 07:33 PM
Need Help - Real problems finding OEM Fender Flares DonManoc Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 10-20-2003 09:16 PM
Who sells fender flares w/ s13 silvia conversion? INEEDACAR 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 22 05-25-2003 01:06 PM
Tell Me About Your Fender Flares Drumtundra Tundra 0 10-02-2002 11:16 AM
