#16
Re: 92 Lesabre no heat
is this blowing fuses at all because my dad had same problem if fuses are blowing like to never found out but under passenger side and we unplugged every sensor or relay and the last one we pulled it never blew a fuse since and it had something to do with the dinger and still works fine. but if not blowing fuse thats probably not whats wrong.
#17
OK FUSE 2 60A is good. The square box looking fuses were all jumbled and put in randomly so they don't line up with the diagram. I did however check the one with the purple and black wire and it was showed voltage from the terminal. I swaped the fuse with another like kind with no change.
Can you tell me where the power for FUSE 3 comes from? I can see the red wires running from behind the fuse panel but was wondering where they start from. From both sides they run into a bundle that appears to disappear behind the firewall.
2005 Chevy Equinox LT 186,000 mi 2004 Buick LeSabre 200,860 mi 2011 Infinity G37x 103,000 mi |
#18
#19
I checked the Orange wire from the harness that would go into the control unit and it read 11.6volts. The blue wire read 8.4v. There was another orange wire coming out of the control unit but it read zero when the connectors were plugged in. Not sure if both wires are related other than color. I'm going to follow the hot orange wire to the circuit board and see what that reads. I have to take it apart first.
#20
ok..I bypassed power across the orange wires in the harness and the blower motor came on. Does this mean the problem is with the Climate Contol Module? I was a little surprised with the wire being hot at all times. I didn't have to have the car in RUN to bridge the two wires.
2005 Chevy Equinox LT 186,000 mi 2004 Buick LeSabre 200,860 mi 2011 Infinity G37x 103,000 mi Last edited by 3echo9; 12-23-2010 at 02:37 PM. |
#21
Anyone have any suggestions on how to find a used C67 manual control module? I've checked with all the local junkyards and even many I've found online. I guess I'm looking for a junkyard that specializes in GM.
#22
This may be the actual control on the dash itself. Or are you looking for the programmer box for C67? Either way these might be ones to call as long as you can be clear which part you're wanting. I've ordered a part from one of the yards and they charged about $20 shipping for a heavier part for 150 miles away. It might be worth checking some of these close to Dayton. Check your private mail here on site. |
#23
#24
Thanks, imidazol97 for the lead on the control module. Took a road trip yesterday afternoon and picked it up for $35, put it in this morning, and we're back in business. In fact, there's no hesitation between switching from heat to a/c and the rr defogger comes on with the first push. I think the control module had been on the fritz ever since I bought the car 7 yrs ago.
#25
I was getting ready to suggest some that aren't showing parts in the website lists. There's one in Richmond on the far northwest side that is a possibility. I'm glad for you that it was the control panel. And it works. Thanks for coming back to let everyone know what you found. That may help another poster. |
#26
Thanks, again.
