Old 12-23-2010, 09:36 AM
scarecrow0529 scarecrow0529 is offline
Re: no spark
Originally Posted by Tony View Post
Thats why I said take a closer look at the belt, you might have lost some teeth on it which would make it loose and wouldn't give the crank anything to grab to turn it.
yes thank you.
Old 12-23-2010, 02:32 PM
Re: no spark
ok new timing belt on, turned the key fired right up and sounded pretty good maybe a little hesitation but when i took off first gear was good but went into second gear and it started hesitating really bad plus my gauge cluster went all screwy. (tach., gas, temp., and spedo. ) ecu still throwing code 20. i am thinking i might of blew something when the starter had a wire start sparking and blew off my neg. battery cable. idk lookin for ideas. thanks for the help so far.
Old 12-26-2010, 08:41 PM
Re: no spark
it was the ground wire(the one that goes from the valve cover to the front frame). replaced it now it runs fine no problems.
Old 12-27-2010, 08:31 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: no spark
Its amazing what a ground can do. I actually don't have that one hooked up, but got another on the motor mount by it and made the other grounds better as well.
Tony
91 Civic Sedan DX - Stock 287k Miles
no spark no spark NO SPARK!!!!!!!!!! javatrooper Cherokee 8 08-17-2013 11:02 AM
Spark, Fuel, But not fuel on spark plug? MoonChld454 Cutlass Series 5 05-02-2004 03:59 PM
No Spark at the Coil Pack/no spark to the plug wires crosscypher Off-Topic 13 02-04-2004 06:01 PM
Spark Plugs + Spark Plug wires ricodemus Engineering/ Technical 4 02-27-2002 12:23 PM
