Old 11-13-2010, 02:33 AM   #16
CBPerformance
CBPerformance's Avatar
Re: Honda Civic SiR II
Thanks for that, I will look into that one
CBPerformance is offline   Reply With Quote
Old 11-13-2010, 05:34 PM   #17
CBPerformance
The gear lever is now complete and ready for painting
Moving on to the foot pedals. For the lever I have used a piece of copper wire bent to shape and hammered flat, to this I will epoxy a piece of evergreen styrene cut to the size of the detail master foot pedal that I will use this will be painted matt black before the photo etched pedal is attached.
Old 11-14-2010, 01:28 AM   #18
CBPerformance
Finished painting the gear lever
and fitted the clutch pedal to dash underside, brake and accelerator to go.
Old 11-14-2010, 08:28 PM   #19
Lownslow
Lownslow's Avatar
nice work on the dash
Lownslow is offline   Reply With Quote
Old 11-15-2010, 12:59 AM   #20
CBPerformance
Thanks for your coment lownslow
Old 11-28-2010, 01:35 PM   #21
CBPerformance
Work on the Civic is a bit slow at the moment, I have ordered some parts from From Scale Dreams, they have not arrived yet.
I have done a bit of painting to the chassis, adding some washes and a bit of dry brushing to add a weathered effect
I have also been trying to get rid of the sun roof showing through the primer on the body and filling a small crack I discovered on the rear bumper, almost ready for paint.
Old 11-30-2010, 03:08 AM   #22
CBPerformance
Got a coat of silver on tonight, I am pleased with the way it has come out.
I usually just polish the paint after it has had a couple of weeks to harden up, and I always get a good shine, I am thinking this time that I may shoot a coat of clear over the top first just to see if I get a better result.
Old 12-01-2010, 02:15 AM   #23
Scrible
As far as I know, metallic paints lose their shine and become dull after polishing, so if you really want to polish it, you need to clear coat it first.
Scrible is offline   Reply With Quote
Old 12-01-2010, 03:48 AM   #24
CBPerformance
Yes I have found that in the past especially silver, I have flicked a coat of clear over the silver tonight. I am very pleased at how it has come out
Old 12-02-2010, 02:03 PM   #25
CBPerformance
Well things went bad with this project last night. My order of Kens Fuzzy Fir arived finally yeasterday so last night I decided to flock the floor area. Not sure what went wrong, this is not the first time I have flocked the floor of models although in the past I have always used Detailmaster product.
It turned into a horrible mess and its not going to be easy to fix. I have spent hours trying to remove the mess but its not going well, so I am not sure if I will be able to continue with this build.
2004 Honda Civic SiR/Coupé Chopped! white2abbit Graphic Manipulation 16 12-01-2003 04:05 AM
Honda Civic SiR njh WIP - Street 15 06-18-2003 05:01 AM
