Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-25-2010, 05:06 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Coughing Hearse
Did you correct the trouble codes yet?
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-25-2010, 09:57 PM
Filmfest Guy Filmfest Guy is offline
Re: Coughing Hearse
Yup, trouble codes clear, no new ones and problem still exists.
The absolute last thing I want to do is start messing with the carb, but there really isn't anything else to check, replace, clean or repair.....
1990 Caprice Classic Hearse...built by Superior. Olds 307, stock (so far)
Old 10-25-2010, 11:43 PM
Blt2Lst's Avatar
Re: Coughing Hearse
If you don't know when the last time the carb was rebuilt, it is probably time..
It made a world of difference when I had mine done.
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 10-26-2010, 09:04 AM
j cAT j cAT is offline
Re: Coughing Hearse
what about the EGR replacement ?
Old 10-26-2010, 09:14 PM
Re: Coughing Hearse
What doesn't make sense is that there would be a carb problem after the car overheated.
And the carb has never been done. When you rebuilt yours, did you buy a re-manufactured carb, or use a carb kit in the original?
Old 10-26-2010, 09:17 PM
Re: Coughing Hearse
The EGR has been replaced, and there was no difference in the "chuggle" problem.
I cannot express how frustrating this is now!
Old 10-26-2010, 11:49 PM
Blt2Lst's Avatar
Re: Coughing Hearse
Just a thought, have you checked the vacuum operated exhaust valve on the left side downstream from the exhaust manifold?
If it frozen in the wrong position, that may cause some sort of exhaust restriction and maybe some driveability problems. Not sure what happens when these fail, just my theory. To check, apply vacuum and observe valve, plunger should move freely and it should hold vacuum also,
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 10-26-2010, 11:53 PM
Blt2Lst's Avatar
Re: Coughing Hearse
Stranger things have happened..
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 10-26-2010, 11:55 PM
Blt2Lst's Avatar
Re: Coughing Hearse
I had these guys rebuild mine.. Worth the money IMO.
http://smicarburetor.com/products/sf.../productID/432
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 10-27-2010, 08:56 AM
Re: Coughing Hearse
remove the new EGR valve plug the exhaust port that is now in view. check to see that the port going to the intake manifold has vacuum.
Old 10-27-2010, 07:55 PM
Re: Coughing Hearse
the valve is working, albeit slowly. It does open fully, and hold vacuum.
(I had high hopes for this one!)
Old 10-28-2010, 11:23 PM
Re: Coughing Hearse
Took the car through its annual mandatory emissions test today, and passed with flying colours. Although HC has increased marginally from .61ppm to .74ppm, NOX and CO both dropped.
Does this give anyone any more ideas?
Old 10-28-2010, 11:42 PM
Re: Coughing Hearse
Checked the site, unable to find an application to match my carb.
This would be one of the last options, simply due to the cost....
Old 10-29-2010, 10:16 AM
Blt2Lst's Avatar
Re: Coughing Hearse
You should have the electronic q-jet carb, they do have them or they can rebuild yours.
Rebuilding yours is the least expensive way to go.
1992 Camry LE 2.2
1996 Suzuki RMX250
cough cough... LOSER! 1986Z28 Camaro Discussions 21 09-30-2006 12:32 AM
cough cough Allegretto Caprice 7 11-17-2004 10:47 PM
cough grind cough clank sputter Jet-Lee Escort 24 05-06-2004 09:50 AM
*cough *cough HELP ME! *cough *cough budd91crx '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-12-2002 05:25 PM
Tags
307 , caprice , surge
