| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
Show Printable Version | Email this Page |
#16 | |
Re: Ferrari Enzo - Tamiya - 1/24, update 1
Keep the progress coming. Threads like these get me motivated, everything is looking great. I also think a red version of the third pic down with white would look good.
| The Following User Says Thank You to MidMazar For This Useful Post: |
rallymaster (03-30-2011)
#17 | |
I say blue with white stripe or red/white nose 2nd. Looking good so far. Im in
Another day on the job! |
#18 | |
i agree with midmazer, this is a motivating thread. Keep it up
#19 | |
Puts my current Enzo build to shame..
Great detail work!
#20 | |
coooolllll....
#21 | |
Thanks guys for the comments!
I will do an update of recent days, but man, I make a lot of pictures. SORRY! The subframe was also sanded and painted gunmetal ![]() The engine was painted and here I tried the effect of sand molds to reproduce. On the picture is not very clear to see, but it has certainly worked. I am in that regard are very satisfied ![]() ![]() Here the effect is somewhat easier to see, do not forget that the Tamiya parts were completely smooth ![]() I removed the reaction rods, I found it a little too fake ![]() The front was painted aluminum ![]() The engine mounts and arms are satinblack with carbon. Also, the new reaction rods can be seen here ![]() A close-up ![]() And a different angle ![]() The supports for the reaction bars are painted gold, I think that is very similar. ![]() ![]() The side of the gearbox, wasn't that good, I'm will try to make something different ![]() As with the pulleys and belt ![]() Just a reference photo for myself, so I can glue the pulleys in the right spot ![]() And two photographs to see how much space I have between the engine and bulkhead ![]() Not so much ![]() Preview of the suspension ![]() The belt removed ![]() A number of pulleys will be replaced by metal ones ![]() And here I start with a piece of tin, to make the sidepanel of the gearbox ![]() First I created a template with tamiyatape ![]() And then pasted on the tin and cut out. ![]() Then with a centeringhole and a few screw holes, to give some realism ![]() The generator was equipped with a PE fan and pulley ![]() In the meantime I'm also working with filler, to fix the sinkmarks of the monocoque ![]() ![]() You need to have another look, but right above the alternator, I have a sensor in the 'tube' installed, this will be later wired ![]() The mounting rings for the drive shafts are fitted ![]() ![]() And the monocoque has been a first primer, to detect flaws ![]() ![]() Oops so, we continue sanding ![]() This net was not very convincing, so I got rid of it ![]() And in reference to the form later ![]() From my reference photos showed that there is no seam in the tunnel, So I glued the innerpart already in. It should come in later, but now I can fix that seam and make it look better ![]() This is more visible ![]() The firewall has been installed already too, again to fix the seams. ![]() Only I have this sink marks overlooked, we will solve that. ![]()
Nothing Beats a TurboCharger!
#22 | |
Meticulous work there! Have you taken a look at the cabin floor yet? Just a heads-up, on my two Enzo kits both the cabin floors are crooked, so it could be a mass manufacturing defect that's worth noting before you do any detail painting.
#23 | |
@KAho; Thanks, No I didn't. But after your suggestion, I took the floor and testfitted it, it does fit nicely, so I dont need to worry there.But thanks for the heads up!
And again an update. Much time went into trying to rebuild the cockpit to see if it is realistic to keep it. I had a horrible accident when applying the carbon-decals, but just scroll down to see Just a dry fit to see which parts of the cockpit to see where carbon needed to be applied The various carbon sheets, I will use different kinds through the build The rear part of the monocoque was given a light gun-metal color And we started with carbon Here is the misery of the melt-down, especially the passenger side was melted quite bad Very obvious to see here, the waves and the passenger side is quite significantly different in shape I've caught the doors there and show that the problem lies crap.... And so I started to try to get the original form little by little to come back, at least I tried The other side AfterI took a clothespin apart and with two strong clips on top, a kind of printing press was made to straighten out the roof Just like the windshield pillar In between: this is what my first attempt to look like carbon The inside (not finished yet) And after two days with the 'press', it looks like this, still warped, but a lot better. The windshield will cover much, and it also seems to cover enough to bail Yet I am still not satisfied 99% And the press goes back on Another picture of my carbon attempt, I tried to make some cuts in, because they work with carbon pads and those are not always straight either. Here I experimented with a little smoke on the carbon, the upper left is carbon, the lighter next to it is just as I decalled it. I find it slightly more realistic with smoke. And meanwhile, I also continued with the engine, I put screws on the cover plate I tried to improve this pulley, but I quit and when for a better alternative All pulleys are mounted, including the two guide-pulley's. 6 in total for the "snake-belt" oops, I lost a screw And with the belt on it. I must say that I am quite satisfied. It adds some realism to the engine, too bad that it will not be visible after installation. Then my hands started to itch and I the painted valve covers, again with the effect of 'sand-casting recreated It starts to look like a engine I will work with photoshop to edit photos, the white balance is not good, as is the contrast / exposure And the last for now Please send your comments
