Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 11-04-2001, 09:48 PM
Jay! Jay! is offline
Horizontally Opposed
Originally posted by brndp
okay..so could you describe in detail how you do the 1st to 2nd to drive thing? thanks.
I don't; I have a manual tranny. I've never force-shifted an auto tranny. Sorry.
Hierarchy of Subaru:
(Click to see mine!)
Old 11-04-2001, 10:35 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: REAL RACING Secret
Originally posted by Nizmolee
racing tips with automatic.. at a standstill you must first put the gear to Neutral b/c there are pressure in the brake lines which take out added power from torque. you can feel the brake pedal go all the way down, when it does put gear in Drive with Overdrive off. Rev at 3000 rpm and when light changes off you go! have fun!
This is the only other way I know of with an auto besides power braking. The only problem with this way is it is very hard on the tranny belts. You could cause them to loosen and slip or snap, so be very careful.
Old 11-04-2001, 11:04 PM
brndp brndp is offline
cool...good info...by the way..this may sound stupid but i haven't bothered to look where the overdrive button is on my maxima...so where is it?
Often, it's under the left side of the shift lever, where your thumb rests, or a bit lower.
Old 11-04-2001, 11:37 PM
black019 black019 is offline
what he said
High Octane Boards - Members Wanted
http://www.mnbmotorsports.com/forum
Old 11-05-2001, 12:35 AM
unless your racing, should overdrive always be oN?
Old 11-06-2001, 02:25 PM
CAptynCrunch CAptynCrunch is offline
Ok, i mean no offense with this, and it's no directed at anyone in particular, just a broad opinion. But if you can't do something as simple as locate teh overdrive button you aren't ready to race yet. You shouldn't try racing(i mean real racing with those amazingly weird things called turns and corners, not this drag from light to light bullshit) until you know what your doing.
Remeber, a poser has a turbo, a racer can tune one.
Keiichi Tsuchiya isn't the drift king,
Michael Schumacher Is.
The only thing better than cars is Music... maybe.
Old 11-06-2001, 03:16 PM
GTS-4 Ben's Avatar
GTS-4 Ben GTS-4 Ben is offline
Send a message via ICQ to GTS-4 Ben
Personally if you are going to race with a stock AUTO gearbox you are wasting your time.. take your mums car home and get a 5 speed for your street racing...
Just because drag cars have an auto dosn't mean your road car is a drag car.. and there are a million difference with their gearboxes..
SDU Southland Moderator
Old 11-11-2001, 03:20 AM
DigitalRacer DigitalRacer is offline
Easiest Way
The easiest way to do that is to probably get a rev-limiter chip. Install it and program it to about 4000, or 4500 rpm. Then you line up, put the car in gear, push in the brake as hard as you can, shift up to neutral, tap the gas to shutoff the transmission lock, shift back down into gear, rev it up, and release a fury when the light changes.
Old 11-15-2001, 12:47 PM
bluevette74 bluevette74 is offline
Banned
I have an automatic transmission in my vette as well. You dont want to power brake your car, the only time you need to power brake your car is when you have a torque converter. When i race i dont go by rpm's i go by the sound of the engine. You have probaly learned when you try to go from 1 to 2 manualy in your car that it doesnt shift as soon as you want it to. I eliminate this problem by shifting just like i would if i had a clutch take your foot off the gas for a split second shift and then mash the gas. it will help. Oh and by the way automatics are the best thing you can have for 1/4 mile racing.
Old 11-15-2001, 01:27 PM
Polygon's Avatar
The Red Baron
Old 11-15-2001, 05:26 PM
I think i know what you're talking about...so you're just saying to start in drive...accelerate and when you hear the sound...just take your foot off and step back on the pedal to switch gears faster?
Old 11-15-2001, 06:27 PM
Banned
no no, start from first then too second and then to drive, and use the same technique that I told you. Most people think that automatics suck, if you can shift manually through 3 gears in an automatic then its perfectly fine for quarter mile racing. In an automatic the gears shift quicker and they eliminate the chance of you missing a gear. Polygon seems to disagree with me and i would like to know why?
Old 11-15-2001, 06:48 PM
hey racing is bad
Old 11-15-2001, 07:00 PM
hakka's Avatar
hakka hakka is offline
yes auto's are better for drag racing, especially with a torque converter and shift kit (like I have)...unless you can pull off clutchless upshifts every time, which is pretty hard. I get the best launches by either powerbraking in second gear then either taking off WOT or gradually taking off in first...my major problem is traction.
eclipse GS 00 Racing jls89 Eclipse 2000+ 2 05-15-2010 05:53 PM
NASCAR Racing Arcade (motion edition) '07 serge_saati Nascar Series 0 02-22-2010 09:46 PM
Caparo T1 on the race track modtor Graphic Manipulation 0 06-10-2009 11:12 PM
looking for american racing rim Dtown218 Cars/Parts for Sale/Exchange 1 05-28-2009 09:08 AM
