Old 10-05-2010, 08:56 PM
exoticnsx exoticnsx is offline
Re: only firing on 4 cylinders...
Originally Posted by rhandwor View Post
Do a compression test on the cylinders that are not firing. Check if the injectors are getting signals use a noid light. Check for power to the injectors.
Hey guys have the same problem on my 1995 sl 5 sp federal , i changed everything and also tried 2 ecu all the wiring is good so now i am thinking to try to check the cam timing or the cyl test like you guys talked about , i live in Atlanta so if somebody close by knows how to check these things i will gladly pay so i could drive the car again . Thanks
