Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 05-09-2010, 08:24 PM   #16
albee9
Re: brakes failed
Originally Posted by Kevcules View Post
If your pedal goes to the floor,you have a leak somewhere.
Check the master cylinder reservoir,it's divided into two sections.
Is the front or back section low on fluid?
The larger section of fluid is for the front brakes and the smaller, the rear.
If you can't visually see any leaks,it must be behind your wheels.Pull them off and look.It's probably leaking at the rear brake cylinders.
Again , take the wheels off....
Kevin
I will
albee9 is offline   Reply With Quote
Old 05-10-2010, 09:15 PM   #17
albee9
Re: brakes failed
Well guys I found the leak, It was under one of the hold down brackets.
that's why there was still pressure to stop the truck and no light .
it must have gave when we tried to haul a load but still no light .
Tomorrow I will fix it and hope there's no more .
Well I just want to say thanks for all the input.
Old 05-10-2010, 10:23 PM   #18
j cAT
Re: brakes failed
replace any other lines that look bad ,,,I buy the brake line in 20 ft rolls ...double flare tool ..
j cAT is offline   Reply With Quote
Old 05-12-2010, 01:07 AM   #19
Scrapper
AF Premium User
Re: brakes failed
how did you come up with water in it? and if you got all the air out and it's still useing fluid you have a leak. it's a slow leak in the line or it's leaking out the back of master cyl. or rezz and you may look inside by break pedal and see if it's wet inside your rug or rubber what ever is covering the break pedal on floor. also fill underneath the the rezz and see if it's wet on the two rubber o'rings that mount it to the master. but you do have a leak if you have to keep adding fluid.
Scrapper is offline   Reply With Quote
Old 05-12-2010, 08:16 AM   #20
albee9
Re: brakes failed
Hi did you not read the rest of the post ???
brake fluid is very hygroscopic, meaning that it easily attracts and absorbs water.
and there was a lot of water and air in the lines .
now all better.
Old 05-12-2010, 09:47 AM   #21
j cAT
Re: brakes failed
now all better.
air is water. not good in a brake system with DOT 3...
good luck ..
Old 05-12-2010, 07:17 PM   #22
Scrapper
AF Premium User
Re: brakes failed
now all better.
i was thinking it mite be your conewter valves..leave cap off of brake fluid it will not be any good. does that answer your ?????????'sssss.
