#16
My gas gauge and miles driven are way off. Despite all the problems I've had electrical-wise for the past 2-3 years now, I think since I recently discovered a bad ground and fixed it (prior to the VSS going out) that the recent installation of the VSS may have been done wrong with regards to the speedometer cable possibly being loose. There's no way I could be showing almost 1/4 tank used (from full) and only having gone 39 miles.
Think the speedometer cable is likely loosened since the mechanic replaced my VSS? They said they could barely reach it when they did it. Would a loose speedo cable affect odometer readings & at the same time SPEED readings? Or just odometer?
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org 1995 3.8L Ford Windstar GL -------------------------------------------------------------------------- "I drive the newest 1995 Ford Windstar anywhere..... when its not broken." |
#17
Re: Need your help: What is part number for Vehicle Speed Sensor 95 3.8L Windstar GL
The speedometer cable drives the speedometer assembly....which includes the odometer.
If the speedometer is correct.....the odometer should be correct. If you have a GPS unit (or can borrow one from a friend)......you could compare the MPH reading from that to your speedometer. Also.....miles driven on the GPS to your odometer........a cheap and easy way to check it out. (I would not buy one just for this test......but a good use for one if you have one, or access to one). I know that you already know this..........but for others...... For fuel economy.....you will need to fill the gasoline tank......drive until you have used a significant amount (more than 1/2 tank), then fill up.......and divide the miles driven by how much it took to fill the tank the 2nd time. The most accurate value is one that you get by averaging a number of tanks of gasoline (I have had 1 tank wonders.....and 1 tank terribles). The gauge can be somewhat inaccurate.......and can only be a general indication of fuel level. At the FULL and near empty are common zones for in-accurate readings.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
#18
