Go Back   Automotive Forums .com Car Chat > Buick > LeSabre
Old 04-16-2010, 10:53 PM   #16
serge_saati
serge_saati's Avatar
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: 93 Lesabre electrical??
Originally Posted by plumcrazy89 View Post
the tranny doesn't shift right and a few other things are wrong.
When you said other things are wrong, what else are wrong?
When you say the fan don't work, you mean the car is overheating? Normally fans activate at 230°F on these models. Unless you start the A/C.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
serge_saati is offline   Reply With Quote
Old 04-17-2010, 09:15 AM   #17
Mickey#1
You need to look at fuse 16 (10 amp) again. This fuse supplies power to the tranny solenoids & the cooling fan relays. Remove the fuse and even if it looks good swap it with another 10 amp fuse. If that doesn't cure the problem then you need to remove the fuse & check for 12 volts at the fuse holder with the key on run. The black meter lead will need to be grounded & the red placed on each of the fuse terminals. One of those terminals should have 12 volts with the key in the run position. Let us know what you find.
Edit - Also check fuse #6 with the procedure above. I have a Chilton's manual that says it's fuse #6 and some online wiring diagrams that say it's fuse #16.
Mickey#1 is offline   Reply With Quote
