Old 04-07-2010, 11:12 AM
Selectron Selectron is offline
Re: 1998 windstar electrical problem???
If you're saying that when you turn the key to the Start position to crank the engine, everything else turns off but then comes back to life when you release the key from the Start position then there's no point in doing that starter bypass which I suggested, because the same thing will happen.
Old 04-07-2010, 11:43 AM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
It's seems to be a short circuit somewhere in the ignition or starter circuit. Cause all the light go off at the same time that a relay click on.
It turns off when you turn it to RUN and START or to START only?
If it turns off on START only, it may be a short circuit in solenoid, fuel pump circuit, PCM or ignition coil.
To diagnose, remove fuse 20, 14, 12 one at the time and see if light still turn off. Engine may crank but not start and you'll locate the problem.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 04-07-2010, 01:10 PM
JJJCOLON JJJCOLON is offline
Haven't tried that, but i will, thanks
