#256
Re: Junkies 97 RS Rebuild(1st timer!)
Ok, well there's one corner that looks like it doesn't have any of them at all. But it also looks like it's not supposed to so..
Guess i'm fine there. My next question is, I took the cam shafts out of the head with the sprockets still on them. I changed one oil seal pretty easily. The other shaft, I believe the exhaust one, has this magnetic black cap on the end of it, preventing me from being able to slide the oil seal over it. I need to take the sprocket off, but how do I do this without it being in the head? Suggestions are welcome, as I can't seem to get a good enough grip on it to break the bolt loose. Should I reinstall it in the head with the caps just long enough to break the bolt loose?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges |
#257
Have someone hold the cam while you use a breaker bar. I'm sure there's other ways but that's what I did. You can reinstall it back in, but you'll mostly just turn it, even with the springs applying pressure.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
#258
Yea you have to hold the gear while you turn the bolt. You may could put the side of the gear in a vice and turn the bolt. Just dont crush it.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#259
Ok, ill try and see if I can figure out something without damaging anything.
#260
Update:
Should be getting my motor and rods and rings back all this week on diff. days. Should be assembling the motor this weekend. Will post if I run into problems, but I dont think I should bc I've already found out everything I didn't understand ahead of time, and I've walked through all the steps, so I should be good.
#261
Held the camshaft in my hands real tight and had someone use an air wrench to pop the bolt loose. Came pretty easily. Got my motor back and all that. Balanced rotating assembly, and now I gotta wait for the rings to come in tom. So im going to go ahead tonight and get the crank in the block at least.
Does anybody know, when the rods go on the crank, which way to the bearing locks need to be facing? I feel like it needs to be a certain way..
#262
Ok so the main bearings laid into the block fine and lined up right. I laid the crank into place, and laid some pieces of plastigauge on the mains journals. Got ready to put the bearings into the bed plate, and they dont fit right. They are the right size, but the little grooves dont line up, like on the bed plate the notch is on the left, and on the bearings the notch is on the right side. Dunno how this happened...guess ill go back to the machine shop.
#263
Are you sure you were using the right bearings for that? As long as you got 420a bearings, they'll line up right. I understand what you're talking about with the tabs not being the right way but don't understand why.
Amnd the bedplate doesn't have a gasket. It has a very fine crosshatching on it so when it gets torqued down to the block it forms a perfect seal. But MAKE SURE that O-ring is between the 2 by the oil filter.
#264
This is a common problem. There is actually 2 different 420a blocks, and thats where the bearing problem comes in. I had the same issue, its not a big deal just get a dremal and grind out the area for the bearing tab to sit in
#265
That's actually exactly what I did, was grind tiny notches in the bedplate journals so theyd fit in. Problem solved.
Dave, make sure the o-rings are where now? Im not sure I understand where your talking about
#266
I'll try to take a pic for you when I go to the garage where my spare block is. It goes between the bedplate and the block. It's the only place that looks like something can go. Right by the oil filter. I believe its the red o-ring that goes there.
#267
Hey which way do the rod journal locks face? front of the engine?
#268
And also, I can re use my arp head bolts right? I read somewhere, although I may have read it wrong, that you can't re-use them. Is that bs?
#269
You can resuse them forever
#270
rods locks towards the exhaust sidE?
