Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Old 11-17-2009, 10:37 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: david-b's 95 Eagle Talon ESi-T Motor Build
Worked on the coolant leak today. Did some sanding down on the T-Stat housing... did a little too much so going to order a spare just incase it still decides to leak.
Finished up the wastegate dump. Dropped right under the tranny. May end up dumping closer to the fender/bumper still, but this is good enough for now.
Just need to make a bracket for the WG still.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-17-2009, 10:58 PM
ned032002's Avatar
ned032002 ned032002 is offline
What are you thinking your going to connect a bracket to in order to secure the WG? Looking at the dump tube, can you just weld a piece of steel near the bottom of it and secure it to the frame somewhere, like with an L bracket or something. IDK just a thought.
Old 11-17-2009, 11:14 PM
david-b's Avatar
Dave is THAT guy
I was going to extend the air filter out and then add a mount to hold up the WG tube off that. I want to connect to something on the motor so that little bit of play will not break the tube. I have a feeling that even with the prothane motor mounts, there'd be enough play to brake it off. Not sure where I'm going to mount yet. Thinking a mount off the tranny might work... but still working out some plans.
75 Monte Carlo
Old 11-17-2009, 11:20 PM
ned032002's Avatar
Now that you mention that, your going to want to mount it to the tranny. Mounting it to the frame will just risk breaking it off.
Old 11-18-2009, 08:50 AM
david-b's Avatar
Dave is THAT guy
Yup. I mean the whole thing is solid, but when the heat starts warming it up at full boost, it's not worth risking it. I want the bracket to come up right underneath it about where the sticker is still (should probably take that off and polish it up one day) so that's why I was hoping for it to sit on the intake pipe. But now I can't really fit one in there.
Actually now that I'm thinking about it, I may end up buying some longer pipe for the intake and making a full CAI. I'll have to find a place to mount the filter properly though. But if that happens, then I can mount the bracket on that pipe for the WG, and it'll be long enough to put the brace right at the WG itself to give optimal support. I'll have to play around with that this weekend.
But now since I have the dump tube on, I can pull the spring from the WG so the turbo won't build boost during breakin. I aimed it for last week to be driveable... will be trying again this weekend. Have to work on my fuel maps tonight and tomorrow.
75 Monte Carlo
Old 11-18-2009, 10:01 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
keep up the good work dude. Cant wait to see some nasty videos
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 11-18-2009, 10:53 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I'm really curious ab your manifold fitting. Have you tried to put the hood down to see how much it hits? I'm planning on bracing my wg off the compressor housing. The internal wg bolts are perfect for that. I wouldn't worry ab it breakin of right away. You could break in the motor now and do that later. It should hold.
Did you get the wb set up in ms? Log your break in runs I would like to check them out. Also what map are you running. is it a gm one? I set you up for a 2.5 bar one but I thought you were using the stock ms one. Is yours 3 bar or 2.5
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-18-2009, 11:05 AM
david-b's Avatar
Dave is THAT guy
I have no idea on what you said in any of this. Not ready for breakin runs yet. When I hit the gas at idle the rpms shoot up and stay there for a while. Still way to rich, still working on the idle... but havne't done that since Sunday.
Ya the hood hits. Haven't worked on that yet. Not important at the moment.
75 Monte Carlo
Old 11-18-2009, 12:41 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Who needs a hood anyways? lol
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-18-2009, 12:49 PM
Holset powered 420a
I was talkin ab your map sensor. If its set to the wrong one it could be affecting your fuel
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-18-2009, 01:16 PM
david-b's Avatar
Dave is THAT guy
I didn't play with any settings for that.
75 Monte Carlo
Old 11-18-2009, 01:35 PM
Holset powered 420a
What was the map sensor you bought? 2 bar, 2.5bar, or 3 bar?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-18-2009, 02:09 PM
david-b's Avatar
Dave is THAT guy
Stock OEM replacement from Duralast
75 Monte Carlo
Old 11-18-2009, 06:40 PM
ned032002's Avatar
Pardon my ignorance but what does the map sensor do?
Old 11-18-2009, 07:36 PM
Holset powered 420a
Manifold absolute pressure Sensor
98 Eclipse GS Turbo
2001 BMW 325i - DD
