Old 03-28-2019, 11:50 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Re: LHD Seven
Assembled with the mirror face installed…
Old 03-28-2019, 05:41 PM
Re: LHD Seven
The gauge has the correct face and the needle is on a raised pin. Custom drawn decals for the gauge and label. Safety pin is correct diameter.
Old 03-30-2019, 05:24 PM
Re: LHD Seven
I milled the "rubber" extinguisher holders from a block of resin and made the hold-down bolts and washers.
Old 03-30-2019, 08:29 PM
Re: LHD Seven
Machined a shift knob and the shifter boot. (More aluminum…)
Old 04-08-2019, 05:54 PM
Re: LHD Seven
Scratch-built bottle jack. (Copy of what I kept in my old Chevy truck.)
Milled from raw resin with aluminum bolts and brass for the screw parts.
Old 04-08-2019, 06:26 PM
Re: LHD Seven
And the crank.
Old 04-09-2019, 10:42 AM
360spider's Avatar
Re: LHD Seven
Very cool.
ItalianHorses.net
Old 04-09-2019, 02:11 PM
Re: LHD Seven
Thanks!
I drew up a label and printed a decal then slightly weathered it. Yes, it's a Binford.
Old 04-09-2019, 07:40 PM
360spider's Avatar
Re: LHD Seven
You know, having slowed down, way down in my building, I started to appreciate these "models within models" on a totally different level.
ItalianHorses.net
Old 04-09-2019, 08:51 PM
jeffmorris jeffmorris is offline
Re: LHD Seven
Scale-Master, How can you work with very tiny parts unless you shrink youself to 1/12 scale?
Old 04-10-2019, 03:55 PM
Re: LHD Seven
Think this is small? I also work in 1/24th and 1/43rd.
Finally got around to balancing the tires…
Old 04-10-2019, 05:47 PM
Re: LHD Seven
Then I realized I had to make a tire iron to install the wheels… Yes, it has a hexagonal recess and actually fits and works on the lugs.
Old 04-10-2019, 09:18 PM
360spider's Avatar
Re: LHD Seven
How do you make a hex inside? Hex tubing of sorts? Or is it resin cast?
ItalianHorses.net
Old 04-12-2019, 12:59 PM
Re: LHD Seven
I made and installed the padded tunnel cover. (It matches the seat padding.)
Old 04-14-2019, 02:22 PM
Re: LHD Seven
First I broached the hex into a lead blank with a machined male hex tool. The plan was to solder it to a brass rod and then machine the outside, but the lead turned out to be too soft to function without rounding/stripping out. So I cut up the four-way tire iron I had and reshaped and bent it into the single type. It's made of zamac and is strong enough to do the job repeatedly.
