Go Back   Automotive Forums .com Car Chat > Automotive Art > Car Modeling > WIP - Muscle Car / Hot Rod
WIP - Muscle Car / Hot Rod Post topics for any "Works In Progress" Muscle Car-Hot Rod vehicles projects in this sub-forum.
Old 07-14-2009, 06:27 PM   #211
white97ex
white97ex's Avatar
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: Pro Touring Camaro of a different ......size?
How about a statistical update as well, this build is posted on 3 different forums. A car modeling forum and 2 car enthusiast forums:
The build started in November of 2005 with hopes of completing it within 12 months.
It has been viewed 51622 times and spans 33 pages between the 3 forums.
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
white97ex is offline   Reply With Quote
Old 07-19-2009, 10:38 PM   #212
white97ex
white97ex's Avatar
Is there any way I can get a mod to change the title of this thread? Is that possible? Maybe 1/12th scale Pro Touring '69 Camaro?
Old 07-20-2009, 10:38 AM   #213
mike@af
Captain Over Engineer
mike@af's Avatar
Fixed.
-Mike
mike@af is offline   Reply With Quote
Old 07-20-2009, 03:53 PM   #214
white97ex
white97ex's Avatar
Re: 1/12th scale Pro Touring '69 Camaro
Thanks Mike!
Old 07-24-2009, 08:06 PM   #215
white97ex
white97ex's Avatar
Well I think its about time for an update on this thing. I've taken some time off to try and re-arrange/begin re-modeling my house. As well as working on some smaller 1/24th scale masters to cast and sell. I've also found someone who is going to machine the wheel sleeves for me. As soon as I get those back, I will get started on the third set of wheel centers. I also need to work out a template for the bolt pattern so that when I go to drill all of that stuff it is correct this time around.
I dug out the old brake molds and cast some of those parts. I want this car to be as realistic as possible, incorporate cutting edge technology and not break the bank. Well I thought the perfect place to cut back on cost would be the brake rotors. Instead of having 4 rotors machined out of aluminum, I decided to re-use the resin casts I had for the front rotors. I found a picture of a ZR-1 Corvette's front carbon ceramic rotors:
To be honest, looking at this thing a second time, I may do my best to duplicate those rotors as well. I think that anodized blue look will fit right in behind the wheels. Anyway, after getting some help on how other people are achieving this look, in scale, I devised this method:
I started with a base of flat black. Then I dug out some Duplicolor Gunmetal. I held the can away from the part so as to only get some spatter of color, repeated until I had the desired effect.
And now the finished part:
Now that I see them side by side, they need a little bit of work, more of a metallic look than a black look...
Old 07-25-2009, 03:57 AM   #216
mrawl
mrawl's Avatar
Your rotor is excellent! That will look superbly realistic. Well, actually, how about more, smaller holes? Use a pin perhaps and just create a whole lot of little pin-pricks?
Mark R
mrawl is offline   Reply With Quote
Old 07-25-2009, 10:24 AM   #217
white97ex
white97ex's Avatar
They really aren't that out of scale. Remember this thing is 1/12th scale. its approximately 30 MM in diameter
I just went back and looked at the picture of the vette rotor. If you compare to that rotor in particular, it doesn't look realistic. They were however originally designed to mimic a set of Baer drilled rotors..
Old 07-26-2009, 01:27 AM   #218
mrawl
mrawl's Avatar
Fair enough, they do look great as is, for sure.
Mark R
Old 07-26-2009, 08:05 PM   #219
tuned.by.twenty
AF Vendor-TBT's Owner
tuned.by.twenty's Avatar
Wow! Good work on the rotor.
tuned.by.twenty is offline   Reply With Quote
Old 01-23-2012, 10:39 PM   #220
white97ex
white97ex's Avatar
I stopped by Wild Bill's in Irving today and browsed around a little. I came across some HPI Wheels that I thought were the right size. From there, I went to Rockwall and stopped at Hobbytown USA for some more plastic tube. There, I found some HPI tires, Falken Azenis I believe. After spending too much money, here is what I came home with, They are bigger than what I was hoping for though hopefully I can make them look right. Not quite as impressive as fully machined, or scratch built, however, It will hopefully save time and get me motivated for this thing.
The HPI wheels and tires
With the 1/12th GT500 wheels
A couple of views showing height/size difference
Finally, a couple of shots of the wheels under the body. The GT500 wheel and tire in the back, the HPI wheel in the front
One thing I have learned with model cars, more often than not, bigger wheels typically look better, not sure how I feel about the HPI wheels though. I think they are on the verge of too big.
Old 01-23-2012, 10:49 PM   #221
white97ex
white97ex's Avatar
A comparison shot for wheel size. This is a 1:1 first gen with ZR1 wheels
Old 01-24-2012, 05:36 AM   #222
Shovel
Shovel's Avatar
Russell, to me the wheels look great. Especially after viewing your last pic.
They seem to be the exact thing/ size for it.
Keep up the great work.
Mark
There will always be the need for speed.
Shovel is offline   Reply With Quote
Old 01-31-2012, 12:57 AM   #223
white97ex
white97ex's Avatar
The more I look at that picture of jackass (the full size Camaro I posted), the more I think the wheels may be ok the way they are, and just alter the width of the fronts.
Then change the body color back to the original sunset orange metallic or going with cyber gray metallic and paint the wheels aluminum with a gunmetal center....
Old 01-31-2012, 05:24 PM   #224
Shovel
Shovel's Avatar
I agree with you Russell.
As for the color scheme personally I would go for the cyber gray metallic and aluminum wheels with a gunmetal center.
Mark
Old 01-31-2012, 11:28 PM   #225
white97ex
white97ex's Avatar
Some better pics of the wheels. They feel too big at this point. They scale out to ~25. Which in my mind, is just so wrong for an old muscle car
