Old 03-01-2019, 06:20 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Re: LHD Seven
Made the flanges and the mounting hardware for the air cleaners.
Old 03-03-2019, 12:45 PM
Re: LHD Seven
Added the stitching to the steering wheel and mounted it to the crush sleeve.
Old 03-07-2019, 12:18 PM
Re: LHD Seven
Finished the air filter set. Foam filters on hard plastic bases that use hose clamps to fasten to the the intake horns.
Old 03-08-2019, 03:41 PM
Re: LHD Seven
Made and installed all the hose clamps (including the hex head worm drives) for the fuel lines and radiator hoses.
Old 03-10-2019, 11:20 AM
Re: LHD Seven
Finished the stone screens and fasteners for them.
Old 03-11-2019, 10:41 AM
360spider's Avatar
Re: LHD Seven
Great detail, as usual. Stitching on the wheel - decal?
ItalianHorses.net
Old 03-17-2019, 03:32 PM
Re: LHD Seven
Yes, decals for the stitching.
The radiator cap is finished. Machined aluminum/custom decal.
Also made the overflow tank and mounting hardware.
Old 03-18-2019, 05:16 PM
360spider's Avatar
Re: LHD Seven
Looks real.
ItalianHorses.net
Old 03-19-2019, 12:42 PM
Re: LHD Seven
Thanks Spider!
From the near start of the project I planned to make the spare tire and support section of the frame removable for part-time racing. The main bolt to hold the wheel to the car frame was fabricated from brass.
The hold-down strap with ratchet buckle is scratch-built. I also made a "working" connector for the wiring that powers the license light and machined all the mounting hardware.
(License plate/frame and wheel are also made from scratch.) Looks like I better hurry and finish it before the tags expire…
Old 03-20-2019, 04:21 AM
Kjenjak's Avatar
Kjenjak Kjenjak is offline
Re: LHD Seven
This is so unbelievably awesome...
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
Old 03-21-2019, 07:29 PM
Re: LHD Seven
Thank you Kjenjak!
I cut and installed the front fender welting…
Old 03-25-2019, 05:33 PM
Re: LHD Seven
It has wings… Or front fenders as we call them in America.
Windshield and roll bar are installed and fitted to accept the brass roof too.
Old 03-26-2019, 09:52 AM
360spider's Avatar
Re: LHD Seven
Woo, on a finish straight! Looks terrific.
ItalianHorses.net
Old 03-27-2019, 12:01 PM
Re: LHD Seven
Thanks! Let'sTime to make the ubiquitous (at least in my cars) fire extinguisher. The bottle was turned on the lathe from aluminum.
The bottom has the correct "dimple".
The head with gauge and nozzle also turned from the same stuff.
The handle pieces were freehand milled and then hand finished before being painted black.
hope this is the finish run for it...
Old 03-27-2019, 06:56 PM
Re: LHD Seven
Rear-view mirror and mount parts, all aluminum.
