Old 05-08-2010, 11:28 AM
Porsnatic Porsnatic is offline
Re: Jordan 191
This is what I call A PERFECT MODEL!..Nothing less to say.
Old 05-08-2010, 01:09 PM
Big Kahuna Big Kahuna is offline
Re: Jordan 191
This is really not fair.
Old 05-08-2010, 03:36 PM
sportracer02's Avatar
Re: Jordan 191
Looks like the real thing, a top model !!!
Micha
Old 05-09-2010, 07:39 AM
dpbeetle's Avatar
dpbeetle dpbeetle is offline
Re: Jordan 191
That´s it!!! A great build. Sometimes I think it´s a real car.
Ciao
Dirk
Old 05-09-2010, 10:45 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Re: Jordan 191
This man is something!!
gio
Old 05-10-2010, 01:41 AM
klutz_100's Avatar
Re: Jordan 191
[Drops dead in a faint] ...... bonk!
Old 05-10-2010, 02:50 AM
maxone's Avatar
maxone maxone is offline
Re: Jordan 191
Thank you very much, jaykay
Old 05-10-2010, 12:12 PM
f40 f40 is offline
Re: Jordan 191
Wow Details are endless Stunning work.
Old 05-10-2010, 04:49 PM
quadzero's Avatar
quadzero quadzero is offline
Re: Jordan 191
Not much I can add to this. When you see fine art like this, you just kinda stand back and stare.
Old 05-11-2010, 11:27 AM
Robi J's Avatar
Robi J Robi J is offline
Re: Jordan 191
Superlatives are not enough...
R
Old 05-11-2010, 01:48 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Jordan 191
Supreme work Jaykay! Thanks for giving me that extra push of inspiration! Keep up the phenomenal work.
-Mike
Old 05-11-2010, 01:57 PM
coolcat28 coolcat28 is offline
Re: Jordan 191
Simply mind blowing a masterpiece it is so depressing just by looking at your work since I know I will never achieve your level of detail building but anyhow still enjoy watching you build Thank you Jay!
Old 05-13-2010, 12:35 PM
jaykay640 jaykay640 is offline
Re: Jordan 191
Against my own expectations I have made some more progress already, so here come some new pictures :-)
It was finally time to glue the monocoque to the undertray. I did that with epoxy glue after first attaching the sidepods to the monocoque. Like this I had better access to them and it was easier to ensure they ended up in the right spot.
After everything was in place I mounted these meshes inside the sidepods. I guess they are to protect the radiators from debris. To be honest, they’ll hardly be visible, but I got carried away when making the etched parts so in they went :-)
Then came the radiators. I had postponed finishing them until the sidepods and engine were in place in case the parts lineup wasn’t correct anymore. This proved to be a wise decision, as some additional filing and bending was necessary to make them sit right.
I started by milling the molded in radiator grids off the Tamiya parts to replace them with etched ones. I also etched these structures that sit on top of the radiators and fix them to the sidepods.
I primed the parts and painted them Alclad Highly Polished Aluminium over a gloss black base. The radiator mesh is divided in two layers. The lower or inner layer has the typical zigzag pattern. This part received a wash to bring out the pattern a bit more. The overlay part just has a very thin horizontal grid. This was painted Alclad HPA as well to blend in with the painted radiator body. As a result the radiator mesh has more depth than a typical aftermarket etching part. Mine are also finer but they are really fragile and tricky to handle :-)
In the picture you see a finished assembly on the left side and the radiator on the right is awaiting the second layer etched part in front of it.
I also made the blue hose connections from masking tape and tiny metal bits and then installed the radiators. The etched parts on top were CFd, cleared and polished and I added those vertical straps that seem to fix the radiators as well on the real car.
Here’s a close up view from the side…
… and a complete sideview of the current state. Starts to look like an F1 car :-)
Thanks a lot again for all your comments and see you for the next update!
Old 05-13-2010, 02:57 PM
f40 f40 is offline
Re: Jordan 191
Outstanding
Old 05-14-2010, 12:58 AM
ewestra ewestra is offline
Re: Jordan 191
Stunning Jaykay, absolutely stunning. I've always liked this beautyfull F1 and you getting the best out of it with all the attention on detail. Again it's a stunner.
Eric
