| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
Show Printable Version | Email this Page |
#196 | |
Registered User
Re: Ping & Pong present: Two VERY Red Ferraris
just awesome, great work Klutz!!!
#197 | |
Great work Klutz, on the window trim as well as on the headlight lenses
Robi |
#198 | |
Hi Steve,
progess on grill, window trim and interior looks great. Some years ago I tried the candle-light-method without success, but I keep it in my mind for small parts
Micha ![]()
#199 | |
Hello Steve,
Nice you started this one again! Makes me think I should work on it also...... But, not for the moment. I have to clean and change my garage, as I want to install my lathe, so..... But, as I said earlier, it's a really nice car. Season's greetings. Jamme
WIP: LaFerrari Tamiya 1/24 |
#200 | |
Finishing up is a longer process than I thought it would be :s
I stretched some clear sprue, cut and sanded it to shape and dipped it in clear orange for some side markers, I made them a little under-scaled as I don't want a big orange blob on the side of the car (let's keep the attention on the decals, huh? )![]() ![]() Maskol in action. I believe this job is much easier with liquid masking than by using regular masking tape. ![]() When I tried to fix the windows in place, I realized that the fit was AWFUL. I decided to cut them up and either not have the larger window or have it partially opened (decision later). I used Dymo printer tape as a guide and my trusty PE saws. ![]() ![]() This is where I am at so far. Very close now! ![]() ![]() ![]() Thanks for looking in,
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
#201 | |
Image Hosting Exceeded
![]() Join Date: May 2003
Spectacular- just a great looking build. Glad to see it being finished up!
Care to tell us how you got the straight edge on the liquid mask?
PHOTOBUCKET SUCKS |
#202 | ||
There is actually a division line molded into the part and I just let nature take its course and the Maskol run into it I have found that in most cases this masking liquid will work well in that way and that it will run reasonably well into wider areas and well defined lines. The trick is to work reasonably fast and in small/medium doses with a fine brush. Once it has started to set up, forget trying to fix it as it will just pull off with the brush - start again. I have also recently been experimenting with thinning it out with water. It works but I still haven't worked out the optimal "thinness". I am total liquid mask convert - next step is to try thinning it and airbrushing it (and then drinking it!)
#203 | ||
![]() My formula for trim 'rubber' is xf1:2 x18:1 xa20:2 which gives a very realistic looking rubber imho (the 'mattness' tends to mute/grey it out a little bit), but as soon as you touch it it gets shiny, also your Vallejo looks extremely smooth. I will try it for sure, thanks bro'. Btw, great idea on the windows, I'm gonna make my Modena windows detachable for that Cali Summer look |
#204 | |
Hmmm... touching !
#205 | |
she's brilliant!
great great re(a)d !!!! keep up the splendid work |
#206 | |
Completed thread here
#207 | |
I am working pretty fast (so far) on the Silver Sister but will update only with things that I do differently than with the red version.
First of all though, I corrected my mistake on the red car and re-painted the headlight fittings the correct color. ![]() ![]() To speed things up and help simplify some of the fit issues, this one is going to be a “light” version and is engine and differential frei ![]() Just the bottom part of the engine will be fitted as there is a small part of it visible through the underside panel. The lack of differential at the rear should also solve to a large degree the fit issue between chassis, interior tub and body at the rear of the car ![]() also, being curbside, it allows me to cut off the source of the bad hood fit and glue it shut ![]() ![]() I experimented with some pre-shading on the upholstery using a pigment marker . ![]() Ultimately the effect is very subtle as I was a little heavy handed with the color coats but it did actually „work”. Tthe 1/1 had a black interior which would have saved a loooad of maskimg but I wanted to try a custom color instead. ![]() ![]() I am using the rotors from the Lioan Loar p/e set on this car. They have a curious design (the calipers are a “sandwich” of 6 pieces) but they actually look very good. Another advantage of these rotors is that they will allow you to easily fix Revell’s biggest mistake in the kit – the brake calipers being the wrong way round (I won’t be doing this though as I don’t want the 2 cars to be glaringly different in this respect). ![]() ![]() Cheers
#208 | |
Nice work, Steven! I really like the pre-shading on the interior, I'll have to try it myself soon.
#209 | |
Authorized Vendor
You're doing my car!!!! I'll just imagine the mess when I start the redhead
![]() Great job buddy, alsmo mine second would be kerbside (or at last I've already steal the powerplant... )
gio
#210 | |
gorgeous work, ski. the 612s with your decals and Lion Roar PE are next on my pile once i finish the McRae Focus (update soon...)
