Old 02-09-2019, 05:56 PM   #196
Scale-Master
Scale-Master's Avatar
Re: LHD Seven
The steering shaft was threaded through the header and into the rack & pinion. Then the scratch-built dash was installed.
Scale-Master is offline   Reply With Quote
Old 02-10-2019, 06:11 PM   #197
Scale-Master
Re: LHD Seven
The beginning of the spare tire hold down. PE frame and milled resin handle; brass hinge pin.
Old 02-11-2019, 01:13 PM   #198
Scale-Master
Re: LHD Seven
The headlights have been installed and wired. I made bulbs for the parking lights too. Radiator is installed. More electrical wiring getting done…
Old 02-11-2019, 07:54 PM   #199
Scale-Master
Re: LHD Seven
We have ignition, wires… They will be routed properly after the carbs are installed.
Also added the ground point for the battery, the clutch hydraulic line and some more oil lines.
Old 02-21-2019, 06:57 PM   #200
Scale-Master
Re: LHD Seven
Been working on the Weber carbs. Adding the linkages and more hardware. Even made the tiny screws to sync the carbs.
Old 02-22-2019, 01:10 PM   #201
Scale-Master
Re: LHD Seven
Throttle cable guide with mounting bracket. Aluminum and stainless steel.
Old 02-22-2019, 04:42 PM   #202
360spider
360spider's Avatar
Re: LHD Seven
Holy smokes. Outstanding updates. The plate is out of this world!
ItalianHorses.net
360spider is offline   Reply With Quote
Old 02-22-2019, 07:43 PM   #203
Scale-Master
Re: LHD Seven
Thanks Spider! It is a fun project...
Got the cable and linkage installed. Still need to wind the return spring.
Old 02-23-2019, 02:53 PM   #204
Scale-Master
Re: LHD Seven
I made and installed the throttle return springs; should be two because one is not safe.
Made and added the lettering to the plug wires too.
Also finished plumbing the rear brake lines.
Old 02-23-2019, 09:17 PM   #205
jeffmorris
Re: LHD Seven
Do you have rear license plate holder? Mine broke.
jeffmorris is offline   Reply With Quote
Old 02-24-2019, 11:34 AM   #206
Scale-Master
Re: LHD Seven
That's normally part of the frame. I modified this one so it can be removed with the spare. If I were in you r position I would make a new one from brass and/or plastic.
Old 02-25-2019, 04:44 PM   #207
Scale-Master
Re: LHD Seven
The tops of the carbs have been installed and the fuel fittings were machined/fabricated and attached to them. A section of the fuel line is on too.
It's starting to get tight between the carbs. But there is enough clearance for the linkages to work without rubbing the wires.
Old 02-27-2019, 12:47 PM   #208
Scale-Master
Re: LHD Seven
Fuel pressure regulator. Because it's mandatory for Webers… Machined aluminum.
Old 02-28-2019, 04:25 PM   #209
Scale-Master
Re: LHD Seven
Added the decals and installed the regulator into the fuel line.
Old 02-28-2019, 10:32 PM   #210
Scale-Master
Re: LHD Seven
Not cast; individually machined from resin. Air filters…
