Old 11-15-2005, 11:28 AM   #181
jdmaccordian
jdmaccordian's Avatar
Send a message via AIM to jdmaccordian
Re: Blue Seven (Parts)
The ruler is actually 12 feet long.
Utterly humbling craftsmanship here.
djMS
jdmaccordian is offline   Reply With Quote
Old 11-15-2005, 11:41 AM   #182
Scale-Master
Scale-Master's Avatar
Wow, bolts a 1/16th long, eh? What diameter are they? Did you thread them, or are they press/glue fit? Did you put a hex head on each?
Yes, I cut hex heads into each of them. The ones that hold the fuel filler in are 0.025 diameter heads with 0.014 diameter shanks. (Inches)
I would call the threaded part on these tiny ones spiral striations more than actual threads, they look a lot like threads, but have little strength so I cement them or just use the friction of appropriately sized holes.
How does the latch work?
Just a friction detent. The lever does not open the lock if that's what you're asking, I'm not crazy.... - Mark
Scale-Master is offline   Reply With Quote
Old 11-15-2005, 11:44 AM   #183
Scale-Master
NOS Bottle Mount in "Trunk"
With the top of the fuel tank too. The filler was posted earlier and is now installed. (Still opens and I didn't even lose a bolt.) The fuel gauge sender is to the right of it.
The clamp for the nitrous bottle works, for now...
There is also a grommet to run the lines through (later...)
Carbon Fiber decals are Scale Motorsport. The "trunk" panels are done with the new Hi Def C/F. I like them, and they are easy to handle... - Mark
Old 11-15-2005, 11:58 AM   #184
Scale-Master
OK, I admit it... Here's my secret. But it's only 6 feet long... Thanks to Steve Boutte for the Photoshop work... - Mark
Old 11-15-2005, 12:02 PM   #185
willimo
Sweet, sweet tiny Hondas.
HAHAHA! We knew it!!
Old 11-15-2005, 02:04 PM   #186
Murray Kish
Getting Old...
Aha!!! I knew it!!!
You've been messing with us all along!!!
Very impressive work. Clearly you have patience and vision beyond anything I could imagine....
Murray
Murray Kish is offline   Reply With Quote
Old 11-15-2005, 02:09 PM   #187
alphalanos
96 EJ6. Future home of boosted B18C1.
alphalanos is offline   Reply With Quote
Old 11-15-2005, 04:42 PM   #188
GvEman
GvEman's Avatar
Awesome work man!
Best Regards
Anton
GvEman is offline   Reply With Quote
Old 11-18-2005, 07:18 AM   #189
Dz!
Amazing.
Dz! is offline   Reply With Quote
Old 11-18-2005, 07:51 AM   #190
white97ex
white97ex's Avatar
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
great work....love the photoshop...nice humor!!
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
white97ex is offline   Reply With Quote
Old 11-21-2005, 12:06 PM   #191
Scale-Master
Pumpkin for the Seven
Started this sub-assembly well over a year ago, but had to wait for part of the fuel system to be built before I could finish it. (It's shown upside down.) At least twenty additional scratchbuilt/machined parts, plus the kit's two, and they were textured to simulate a cast finish. The block with the fittings is the fuel log for both sides of the tank and feeds two fuel systems, one for the Weber F.I., and one for the nitrous... - Mark
Old 11-21-2005, 12:19 PM   #192
675datsun
675datsun's Avatar
Not that your work isn't incredible...but since it's so stunning and real...why do they mount the fuel log on the diff? Wouldn't that heat up the fuel?
675datsun is offline   Reply With Quote
Old 11-21-2005, 12:38 PM   #193
Magliano
Magliano's Avatar
WOW!!
You don't stop, every days theres a new part...
In the end you will turn the key and the model will go away!!! hehehehe
Are you a leprechaun? hahahaha
Amazing job! Unbelievable!!
Magliano
Magliano is offline   Reply With Quote
Old 11-21-2005, 01:21 PM   #194
Scale-Master
"They" don't. Seven's don't normally have nitrous. That would be crazy...
The pumpkin on them is much like a Vette with IRS, in that it is frame mounted and stationary. The fuel tank is a saddle affair on this one. To get the fuel out without a siphon the fittings are mounted low, hence the necessity of the fuel log.
The fuel log is not attached directly to the casting, rather it is on a C/F bracket with an insulated mount.
Heat rises and there is air flow across the bottom of the car. There is also plenty of clearance between it and the ground.
From that block the fuel goes rearward to the pumps and back up and forward to the motor.
I have spent a lot of time (probably too much for "just a model") researching this unique application. A friend at Edelbrock also helped... - Mark
Old 11-21-2005, 01:29 PM   #195
675datsun
675datsun's Avatar
Originally Posted by Scale-Master
"The fuel log is not attached directly to the casting, rather it is on a C/F bracket with an insulated mount.
Gotcha! I understand now...I can't wait to do the tech inspection on this before it hits the track
