Old 09-25-2006, 10:12 AM   #151
porschenut
porschenut's Avatar
Send a message via MSN to porschenut
Re: Eighties Contest Entry: 1988 McLaren MP4/4 (and Introduction)
Amazing.
Euan
You're not meant to use wood...
porschenut is offline   Reply With Quote
Old 09-26-2006, 05:14 PM   #152
Robi J
Robi J's Avatar
JayKay I'm still searching on the dictionary the right word to describe what you're doing...
You're not human.
Roberto
Robi J is offline   Reply With Quote
Old 09-27-2006, 06:05 AM   #153
Pippin1974
Pippin1974's Avatar
You're a Tamiya engineer??? It's incredible the work you're doing!!!! it's Amazing!!!
Pippin1974 is offline   Reply With Quote
Old 09-29-2006, 04:50 PM   #154
Shunter
Shunter's Avatar
It is like reading a novel you do not want to put down. Excellent work.
Shunter is offline   Reply With Quote
Old 10-01-2006, 08:12 PM   #155
jaykay640
Hi everybody again. Here comes another update….and this time quicker than „usual“ :-)
First up thanks for all those positive comments again. I really appreciate this and it is a great motivation to get on with the model.
Robrex…..I don’t think though that you need me to become a better modeller, if that’s necessary or possible at all…..but thanks!! :-)
I managed to get some modeling time and now that the painting of the monocoque is over some things just go quicker as I’m adding new little pieces or stuff I already prepared so here we go with some progress.
Before I could carry on with the gearshift that I gave you a preview of in the last update I had to attack the steering column. Only after this was installed I could put the other cockpit elements in place. You don’t see a lot of it but it “had” to be done and I wanted to make it nice and crisp….which was my main concern. Here’s the real one:
It looks very sharp and undoable in scale but I tried and am pretty happy with the result.
I made the basic shape of the universal joint parts from aluminium on the lathe and then very carefully filed and sanded the details by hand and rotary tool. The columns are 0.8mm brass tubes. For reference I put a ruler….they are quite small:-)
Then I glued on brass PE washers from SRC and airbrushed them semi gloss black. After sanding off the paint from the brass washers they look like this:
Not exactly like the original but close enough and finally here the whole assembly is installed in the nose of the monocoque:
After this was finally done I could also install the part with the pedals and fire extinguisher, the seat and the “armrest” with the gearshift.
The PE screw heads are from a set by MCG ( Model Car Garage ) and the smallest I have yet seen on the market. I fixed them with tiny drops of matt clear paint. I think I’ll tone them down a bit. Like this they are too bright compared to the original.
In the meantime I also worked on the sidepods. Here you see the forward ones.
For their surface finish I tried something different with the CF decals. As you can see in the next picture of a real one they don’t show a bright pattern that changes it’s look with the light but rather has a structure you can feel when you’re touching it.
For recreating this, my home made Kevlar decals turned out to be very useful. Unlike the decals you can buy, their black laser printed mesh pattern is “raised”. After painting the sidepods gun metal grey I covered all the visible surfaces up with the stuff ( which involved a good deal of MicroSol again ). I then sprayed them with a misty layer of gun metal grey mixed with matt clear. Like this the structure is still visible but the colour is uniform. To improve the look I later rubbed the pieces a bit with my fingers which made the raised areas of the pattern a bit glossy.
In the next picture I put them in place ( they are not yet glued though ). You can see I added the big washers and rivet heads that “hold” the mesh inside that protects the radiators from debris on the real car. The mesh will follow later.
The washers are brass PE and I covered them with SMS 1/43rd scale Kevlar decal after a layer of clear paint ( apparently decals don’t stick well on unpainted surfaces ). The decals were a bit too bright so I toned them down with a mix of matt black and clear and added the rivet/screw heads I made from styrene. I may sound silly with all those steps I’m doing to those little bits…but once you start that’s were you get to in the modeling asylum :-)
More importantly you can also see I added the seatbelts. The lap belts are glued to the seat. For the shoulder belts I drilled little holes and fixed them with the PE brackets that come in the Perfect Parts set. I used 0.8mm brass screw heads from Galtran.com. It wasn’t even necessary to use glue. I just pushed them in and they stay:-) I also added the Boss stickers now that the belts were in place. The decals that came in the seatbelt set didn’t react to MicroSol though so I used Robrex’s advice and used some plastic cement. That worked but they didn’t turn matt! :-) Some matt paint will take care of that though.
In between the belts I added the chassis plate. It’s again a dry transfer on a piece of 0.1mm nickel silver. You may remember the big one I made for the box. This is from the same data….but this time in scale….and without the chassis number etched in :-)
While doing all this I also carried on doing more new bits. I started to assemble the “electronic” boxes from my PE parts. Here you can see some laid out in the right order after each one was cleaned with files and sanded.
In plastic kits these boxes always have flat sides but as you will know also from car stereo amplifiers the usually have fins for cooling. To replicate this I etched pieces with varying sizes that I then stack up layer by layer. I use epoxy glue for this because it gives you a chance to move the pieces in the right place. Superglue doesn’t let you do this. The whole process is a bit time consuming and in the end you “just” get one black “brick” from all these nice bits but I think it’s one of these little details that’s worth the effort.
Here you can see the boxes before painting. I also did the mounting plates for the electronic connectors.
Next up is the fuel filler. It’s a PE plate for the base with a turned part on top. The little “holes” in the top ring I filed in by hand. Now it needs some paint. It won’t be very visible after the roll bar is installed unfortunately….
In the next picture of the real car you see the area on top of the tank where the big electronic box and the fuel filler ( under roll bar ) go.
For comparison here is the model with the now painted E-box and the unpainted fuel filler put in place but not yet glued. I have to work on those cables and the roll bar first.
As you can also see I added Bare Metal Foil in the engine bay and on the rear end of the monocoque and the Marlboro stickers on top of the tank.
Those were a story of their own. I have several decals sheets for this model…just in case:-)
First there’s the one that comes in the Tamiya kit which will be used only partially….if at all.
I then bought a Studio27 High-Tech sheet, mostly because of the fluorescent red colour that is a perfect match for the automotive paint I’ll be using for the cowling and rear wing. Then I also got the standard Studio27 sheet of the Japanese GP because the name stickers on the roll bar are different and who knows what else ( you never know and a backup is never bad :-) Finally I already had the Marlboro decal sheet from F1Specialties for all the McLarens. You can just about see in the next picture that the red parts are a little different from sheet to sheet. I don’t wanna get into that fluo red discussion again but this just shows there are differences and I think it’s best to match the paint to the stickers.
The funny ( or not so funny ) part here are the said white Marlboro stickers for the tank. They should be individual letters with no carrier film around them to shine out on the dark and matt underground. So Studio27 High-Tech is the one….not! It turned out they are too small. From the reference pictures in the F1Modeling Senna Giga Special it seems like they were small in the early season ( correct for the Tamiya kit ) but somewhat bigger for the late season car I’m building. Of course both Studio27 sets have the same small logos… The F1Specialties logos have the correct size but I decided against them because the carrier film would show ( unless I over paint them with matt clear ). I chose to get dry transfers in the correct size. They worked fine and are “true to the original” with individual characters:-) So much for being pedantic again….
So much for that ….but I managed to give myself a new problem while taking the pictures for this update. When I put the High-Tech decal sheet back into it’s plastic bag the freakin’ piece of crap got stuck right on top of some of the stickers with it’s glued end. When I tried to peel it back off very carefully a couple of the carrier film bits came off ( %§&X$§#!!!!) and among them of course the red Nr 12 for the nose! I don’t know how I will get that number in place now and I don’t really wanna buy another sheet just for that! Bugger!
Normally the first thing I do with those bloody Studio27 decal bags is to cut off this annoying glued end just because of that. I really wished they could come up with another way to seal these bags! Rant off!
This is it for now. The next update will take a bit longer again as I’m going on holidays for a week :-)
Cheers
jaykay640 is offline   Reply With Quote
Old 10-01-2006, 09:33 PM   #156
2.2 Straight six
That thing got a Hemi?
2.2 Straight six's Avatar
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
that work is just amazing..
Seatbelts Saved My Life
2.2 Straight six is offline   Reply With Quote
Old 10-01-2006, 10:15 PM   #157
CeeElle
CeeElle's Avatar
this is absolutely insane.
CeeElle is offline   Reply With Quote
Old 10-02-2006, 01:40 AM   #158
robrex
robrex's Avatar
Amazing!
You said yourself Jaykay, that getting comments gives you motivation to build more..well reading your thread makes me want to build more!
That's how it's making me a better modeler!
You have raised the bar SOOOOOOO high!!!!
Thanks
Rob
robrex is offline   Reply With Quote
Old 10-02-2006, 01:44 AM   #159
Shunter
Shunter's Avatar
Wonderful work....I love the linkage set-up.
Old 10-02-2006, 03:15 AM   #160
billypee
billypee's Avatar
Send a message via AIM to billypee
Hi JayKay,
Great work and another fabulous update. I will never get tired of this thread.
Cheers,
BillyPee
On the workbench:
Completed WIPs:
Completed Models Gallery:
billypee is offline   Reply With Quote
Old 10-03-2006, 05:58 AM   #161
Scuderia.
Great progress, this build is really moving along. I have a studio 27 hitech decal sheet with a spare no12 if you are interested. I believe the sheet covers 4/4 to 4/8, and I am doing the 4/5b which uses no 27. I am guessing the 12 on the sheet would be the correct size and what you are after.
Scuderia. is offline   Reply With Quote
Old 10-04-2006, 03:45 PM   #162
davesans
davesans's Avatar
Hi JayKay,
Your work is just out of this world
Dave
davesans is offline   Reply With Quote
Old 10-05-2006, 08:30 PM   #163
Marcelo Teles
Marcelo Teles's Avatar
Great, great work Jaykay!!!
Marcelo Teles is offline   Reply With Quote
Old 10-06-2006, 03:28 AM   #164
joelwideqvist
You are so skilled and seem to have so much fantasy to get those details covered. What I really like is that you put down a lot of effort to describe the process, you would probably get a lot of :s and :s just by showing us the photos. But as Rob sais this shows what you can do with a kit if you earn your skilles and breed those with a lot of fantasy, time and motivation. Hope we can keep feeding you that last ingredient.
My hat off and my most humble regards.
Joel
joelwideqvist is offline   Reply With Quote
Old 10-06-2006, 03:50 PM   #165
allnie
allnie's Avatar
Originally Posted by robrex
Amazing!
I would more say - reading your thread makes me wants to give up my modelling career and make suicide . I am many-times Danish IPMS champ and LIGHTYEARS away from the Jaykay level. My MFH FW16 looks like something done by a 5-year old child compared to the MP 4/4.
Best regards
Allan Nielsen
Denmark
allnie is offline   Reply With Quote
