Register FAQ Social Groups
Old 08-28-2008, 07:16 PM
CarolinaCavy CarolinaCavy is offline
Running Extremely Lean
I have a 1996 Chevorlet Cavalier Z-24 and it is running lean. At first I could start it up and it would run good for about 20 mins. but after that it would start to sputter and jerk. So I thought it was the O2 sensors leaning out because I had a bad exhaust leak. I got the exhaust fixed new exhaust all the way header all the way to the muffler. That didn't stop the problem so I replaced the fuel filter and no luck so I replaced the TPS no luck there either. My air/fuel guage is reading lean never touches rich like it is suppose to you know the usually sweaping motion. Any suggestions would be appericated.
Old 08-29-2008, 10:09 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Running Extremely Lean
Is your air fuel gauge a narrow or wide band?
Narrow bands are only accurate at WOT when the car goes into open loop and just dumps fuel. It would also be a bad connection where you tapped into the O2 sensor wire. If it wasn't soldered in place, it really should be.
Wide band A/f gauges are a true reading, but also run $250+
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 08-29-2008, 05:44 PM
It's not a wide-band but its not only the gauge the car skips and jerks. It mainly does it when I really get down on it and then when I try to drive normally it starts to skip and the gauge reads lean. Before this the gauge was sweeping back and forth but now it sweeps lean to ideal instead of lean to rich. I checked the connections and there all fine. Do you think it could be the EGR valve?
Old 08-30-2008, 01:02 PM
Lifted GMT-360!
It could be. EGR's are such a waste on motors. They really don't need them, at least on these cars.
Try getting a used one first before buying a brand new one, they are quite pricey.
Old 09-01-2008, 07:05 AM
Zeifer Zeifer is offline
Could a plugged injector/fuel system, maybe.
Old 09-01-2008, 11:00 AM
Jason/RKBA's Avatar
Jason/RKBA Jason/RKBA is offline
Codes?
Old 09-01-2008, 02:01 PM
Yeah, you probably should have checked the codes before throwing money at it. If you are running lean, you'll get a P0171 code, and probably some others. It might be your MAP sensor. I was runnng rich (P0172), and replaced the MAP sensor, fixed the problem.
Old 09-05-2008, 06:37 PM
Thanks for the information yall. My engine light just went off today so I will check the codes probably tomorrow. Another thing it is after I get down on it and then try to cuirse it starts to spit and sputter I hope its not a burnt valve.
Old 09-06-2008, 09:33 PM
This might help you.
http://www.obd-codes.com/p0171
Old 10-11-2008, 04:24 PM
Ok I got the codes and the only one was for the vehicle speed sensor. So I got it and replaced it and my car is still doing the same thing. I dont know what to do about it. I thought it might be a burnt valve but I talk to a tech and he said it would be sputtering all the time. But what the hell I getting pissed off with it.
