| Register | FAQ | Social Groups |
| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
new engine question!!
hi i have a 96 eclipse gs-t
but i was wandering if i can take, i want to say 92 or 93 6 bolt non turbo engine. If i can change the internals and everything to run more hp. so basically is it possible to make a reliable non turbo engine to a turbo engine if change internals P.s it has the squares flat head like turbo do, not the rectangle tall head if you no what i mean. thanks for all the help i really appreciate it !! |
Re: new engine question!!
The only differences between a NT and a turbo block is the absense of oil squirters on the NT an the higher compression ratio. As long as you put in some turbo or aftermarket pistons you should be fine, its debated whether or not the oil squirters are actually even needed.
Also, 6 bolts only came in 90, 91, and most 92, so be sure you check it out on the 92 and there are no 93 6 bolts. |
sorry if im butting in on your thread but i had basicly the same question.
but... is the N/T engines stock internals still able to hold as much power as the turboed 6-bolt? im wanting an engine for my talon but its heard to find a 6-bolt laying around for very cheap. i would put my own turbo of there anyway... so would it be a good idea? they are alot cheaper 2... http://www.jdmtigerjapanese.com/prod...roducts_id=133 VS http://www.jdmtigerjapanese.com/prod...roducts_id=165 VS http://www.jdmtigerjapanese.com/prod...roducts_id=164 P.S what the difference between the 2nd and 3rd one? again sorry if i butted in. thanks a ton. |
N/T motors have high compression pistons in there. If you take the stock N/T motor and drop it in place in a turbo motor, you're more than likely going to blow something up. The motors aren't made for high compression turbo applications.
So, the best way to do that would be to get the N/T block, swap pistons to low compression turbo pistons, and then swap motor in.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
thanks alot for all the help i really appreciate it!!
I have a 96 eclipse gs-t turbo i planned on getting the non turbo engine like i said and building it from groound up and chaging all the internals so thanks for answering the questions appreciate it. |
its np problem fro butting in either,
its fine |
thanks man.
| Thread Tools | |
