Old 04-22-2008, 09:51 PM
accuab's Avatar
accuab accuab is offline
Changing fuel filter
Are there any tips anyone can give me before I change the fuel filter on an 02 GT. Dad said the fuel lines can sometimes be bent if constant pressure is not held on the nut. I have read the how-to on this procedure. I work on a lot of stuff but used to always just let someone else do the car items for times sake. Any help is appreciated.
'01 Regal GS
Old 04-22-2008, 10:39 PM
Grand Prix SD Grand Prix SD is offline
Re: Changing fuel filter
I would soak the fitting threads with some wd-40 or something, and use a line wrench on the fuel line otherwise it may round over. These can be very hard to remove if rusted or corroded and you can easily twist or break the fuel line.
Old 04-23-2008, 10:59 AM
daejuanj daejuanj is offline
Send a message via ICQ to daejuanj Send a message via AIM to daejuanj Send a message via MSN to daejuanj Send a message via Yahoo to daejuanj
Have you checked the guide?
http://www.automotiveforums.com/vbul...d.php?t=656052
- 2002 Pontiac Grand Prix GTP (81K miles)
Magnaflow High-Flow Cat, U-Bend & Resonator delete
Got3800 Race Day!
Old 04-26-2008, 09:54 AM
rickisrad rickisrad is offline
Soak the fitting with PB blaster a day before you do the replacement. It is fairly simple, just make sure you use a cresent wrench or vice grips to hold the fuel filter from twisting and use a quality line wrench or open end wrench to loosen the fitting. If fitting is stuck or hard to get off, try tapping the fitting lightly with the wrench to loosen some of the rust.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
