| Register | FAQ | Social Groups |
| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
transmission swaping
i have a gs with a 420a, and im looking at a A578 transmission out of a plymouth neon to put in it. i know alot of neons have 420a motors in them but i wanted to make sure it will work. the guy who has the neon doesnt know if its a 420a or not. please help
Re: transmission swaping
I highly doubt it will work. Are you talking about a 5spd or auto tranny? The manuals use the NVT-350 tranny I believe. I dont think you can use any kind of neon tranny. Even though the motors may be the same I think the trannies are a little different and isin't compatible. I could be wrong but I dont think it will work.
Either search a lot and see what you can find out or just get the tranny and compare it to the one in the car.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
The only trannys I know of that will for sure work are the trannys from the Eclipse and Talon 420a, as well as the 95-98ish Avenger 420a. The neon may work, but you better do some more research. Try www.2gnt.com
yes you can use it, BUT! the neon trans has 3:55 gearing so if ur not boostin it its gunna be real doggy, also your eclipse clutch is hydrolic, that neons trans is a cable, so you hafto take you eclips bell housing off your transmission and put it on the neon transmission, then yes it will work,remember to swap the speed gear out of the eclips trans and put it into the neon trans. the a578 is off a sohc neon and thats exactly wat trans you need for the swap, i have that same exact trans in my 98 rs right now, and i blew it, so i am also lookin for a tranny, lol, if anyone has any questions about this swap just ask me, all i hafto do is walk outside and look at my own car, im just warning you now it is going to be alittle doggy with 3:55s, and if you want more proof call hahn they will straight up tell you that they are running that trans in ther 420a eclipse, i hope thats the answer you were looking for
we'll i jsut went and bought a nv-t350 tranny. Does this tranny have the cables or hydralic cluth setup?
Should be hydrolic clutch.
that sucks. i was hoping for cables. doing this auto to manual swap is going to suck!
Nah man you dont want cables. Hydrolic is so much nicer.
well hopefully it'll be worth it! been doin some research and it look like not so much a hard job, but definitly long.
how do i tell if my nv-t350 tranny has a clutch setup or hydralic. or can i go both ways?
What are you talking about? The clutch is hydraulic, silvr already told you that. The master/slave cylinders run off of a hydraulic pump (master cylinder) when you push in the pedal. The master cylinder then pushes fluid down the lines to the slave cylinder and pushes out a little pin that pushes on an arm which engages/disengages the clutch/pressure plate. The only cables used are the shifter cables from the shifter plate to the top of the transmission.
Yes but the guy i bought the tranny from just told me it was a cable clutch, as in no slave and master cylinder, just a cable going from the pedal to the tranny. now i just need to get the cable.
What car did the tranny come out of? Maybe an older neon may have used a cable clutch but I kind of doubt that. I would find out exactly what car it came out of and then look up what type of system it uses.
| Thread Tools | |
