| Register | FAQ | Social Groups |
| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Clutch question
Well I finally got my motor/trans back into the car and got her started up for the first time since October. The only concern that I have is the clutch. I put a brand new ACT 2100 clutch set with new t/o bearing in and got my ACT flywheel re-surfaced to .610 at the machine shop. I torqued the clutch assembly down to 18ft pounds and the flywheel bolts to 100. Bled the clutch system before start-up. My problem is the engage point is right on the floor. It's to the point where it's some-what difficult to change in and out of gears. I tried adjusting the master cylinder rod and freeplay. Where the adjustment used to be, the pedal is about an inch from the floor fully pushed in. So i re-adjusted it to where the pedal damn near contacts the floor with a little freeplay at the top and the clutch is still right at the very, very bottom of the pedal. I'm all out of adjustments I don't know what else to do except try bleeding again? I don't know...If anyone could help me out on this one, it'd be great.
Thanks, Steve |
Re: Clutch question
Most of the problems I have seen with low engagement points are caused by air still in the hydrolic system or the clutch system has been adjusted wrong. It seems like you have tried adjusting everything so I would try and bleed everything again.
You may want to even messure how far your slave cylinder rod is coming out when you push the clutch. That may help you narrow down the problem. Also how old is your clutch line? I had a problem with my clutch not releasing at all occationally and it turned out to be the rubber hydrolic line flexing when the pedal was pushed.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: Clutch question
My buddy's MR2 was fully bled, but the pedal wouldnt come off the floor. We just kept bleeding and kept bleeding and slowly pressure built up and eventually it was normal. Maybe thats going on here?
Re: Clutch question
Mine done the same until we bled it good.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
Re: Clutch question
Well I did one more *quick* bleed because I ran out of brake fluid...Didn't really help much...But anyway new problem. I actually took it out on the streets for a test drive. Number 1 - no brakes! lol I have to pump the living hell out of the brake pedal to get something. I did take the passenger side caliper line off briefly the other day but I did bleed that caliper pretty well so WTF? What's going on here? Do I need to bleed all 4 calipers? I didn't think I had to....Also, Number 2 - my clutch. When it engages, it chatters REAL bad. Like it seems like the motor is going to hop out. I don't understand. Like I said in my first post, NEW ACT 2100 clutch disc/pressure plate. Resurfaced ACT flywheel. I used brake cleaner on the flywheel surface and pressure plate surface to make sure no grease or anything was on either one. Properly torqued the clutch assembly to the flywheel, greased the new t/o bearing and lightly coated the input shaft on the transmission...Why is it chattering? Everything is NEW! Maybe it needs to break in first? I don't know. I even checked all the mounts - all are secure 100% along with the crossmember. Anyone have any ideas on these 2 problems? As far as my engagement problem I'm going to have to get more brake fluid and bleed the living hell out of that thing. Thanks for the help.
Steve |
Re: Clutch question
Yea you have to bleed all four calipers. Starting with the one farthest away from the master cylinder.
Im not really familiar with ACT disc. What type of disc did you put in your car? I though ACT used mostly a stock type carbon/organic disc, but you should get no chatter from that.
Re: Clutch question
Re: Clutch question
My car acts the exact same as yours. I tried everything that you tried. Ultimately, I just gave up and got used to it. Its really not that bad in the end. I bled it dozens of times it didn't do shit.
I think just some of our cars have low engagement points when fitted with beefier clutches.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Re: Clutch question
Measure how much the slave cylinder rod comes out when you push the clutch in.
I would also check that rubber hydrolic line to see if its expanding.
Re: Clutch question
I forgot to mention, also, that on downshifts it vibrates the cabin a tad unless i heel-toe or keep the rpm's up...But as for the engagement problem I think I figured it out. My master cylinder decided to blow up on me last night coming home from my friends house and I had to drive clutchless (oh, what fun). I thought it was the slave at first until I seen the brake fluid leaking in from the master cylinder rod into the cabin. So I had to order a master cylinder rebuild kit and it won't be here until Saturday morning. So maybe the new piston, spring and seals will give me a better clutch adjustment after the quick rebuild on the cylinder. Damnit, just as I get my motor dropped back in and get everything running perfect, stupid shit like this has to happen :-( As far as the vibration, however, it has gotten better since the other night. From a stop it still does vibrate on engagement but not as visiously. Forgot to mention I have the polyurethane main engine mount and main transmission mount in, but not the front or rear (those ones cause way, way too much vibration). But I know before I never had the little bit of vibration on downshifts...Hmmmm
Re: Clutch question
Re: Clutch question
That master will fix the problem. With a leaking master, you typically end up pumping air into the system as you bleed it, so you'll never get it bled. The chattering is normal until the disc is broken in. Takes most people a couple hundred miles with a street disc. A metalic disc can take thousands. DSMs with aftermarket clutches do tend to end up with a low engagement point. EVOs are typically high no matter what you do, in comparison.
On a 2g, the master has a check valve that will pump the system up as you actuate the clutch if you adjust the rod too far "out" (toward the master, to get more master travel). If you find that the pedal is pumping up, back it off just until that stops. That's the longest adjustment you'll ever be able to get away with. Most 2Gs work quite well when adjusted this way (maxed out). If you still have that POS accumulator in the stock line, get rid of it. Odds are it's full of some milky looking HIV infected bullshit that really screws with slave travel. Replace it all with the braided line. And make sure the braided line can't rub on anything, I've blown those POSes out before and it's not fun, having driven clutchless for months myself, back in the good old days... Sounds like you did everything else right, so I'm sure this will all be an easy fix.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: Clutch question
Got the master cylinder rebuild kit and rebuilt the damn thing...Took maybe an hour all together and bled the living shit out of the system. Clutch engage point/travel is perfect now. Not only that but the travel of the pedal feels so much better and smoother than ever before, it's incredible haha. Clutch still chatters a bit but not as harsh as it did. Engage point is close to the floor (which is what i like) and not ON the floor like before. Everything is running smoothly, except my brakes...Still have none lol. Haven't had time to bleed those yet. But anyway, as far as the motor goes - I had to temporairily downgrade the turbo from a 16g to a 14b cause after doing all the work that I did, I come to find out the 16g had WAY too much shaft play. And being that i got a mint condition 14b for FREE i stuck it on there...I'm still somewhat impressed with it. I'm not used to having a turbo spool up that quickly lol. The boost gauge doesn't hesitate one bit going to 17psi, and it holds it quite nice. No boost, oil, antifreeze, exhaust leaks of any kind. No squeely belts...I believe that's a first for me haha. Motor runs strong as hell, also. Hopefully i won't have any more problems with her.
Re: Clutch question
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Clutch question
Well....so much for the brakes...I broke off two bleed screws inside the calipers, both on the driver's side...I tried using an 'easy-out' with no luck. Now I need to find a way to get these damn pieces out of my calipers
| Thread Tools | |
