Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 09-15-2007, 06:44 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
mount locations 99 Cougar 2.5L
I am working on a 99 Mecury Cougar 2.5L, it's a friends car whenever he puts it into reverse you can hear the exhaust slam into the floor of the car. He had to have the flexpipe replaced and they said they would not warranty the work because there is a mount missing and it would break again. Well the front Torque Mount (Roll Resistor) was shot and needed replaced, the motor and tranny mounts seem fine though, and I replaced it and this helped alot you cannot move the engine back and forth now by hand like before but the exhaust still slams into the car when you put it in reverse.
Now from everything I have read there should be 2 torque mounts (Roll resistors) 1 in the front of the engine (which I replaced) and 1 in the back well where is the one in the back located at? I do not see any mount at all.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 09-17-2007, 04:44 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: mount locations 99 Cougar 2.5L
Should be located right behind the gearbox.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 09-17-2007, 06:24 PM
and where does it mount to.
There is no motor mount or bushing or anything then I think I see where it is suppose to be. the transmission has to ears sticking out where it looks like something is suppose to bolt onto it and I would assume the other part would get bolted to the crossmember for the rack and pinion?
