Old 07-05-2007, 07:06 PM
mtterry mtterry is offline
2002 alero rough shifting
ok had problems w/ my wheel bearings, brakes, and so forth.. i fixed everything and im still having a problem w/ my transmission. basically i took it to a transmission shop and they said it was fine, but errors/sensors were making it shift hard. I fixed everything but p0113 which is IAT sensor. i replaced it, reset my codes.. shifted fine for a few minutes, then BAm.. back to hard shifting.. any ideas?
Old 07-06-2007, 12:11 PM
jr6078 jr6078 is offline
Re: 2002 alero rough shifting
Possibly a bad connection at the IAT sensor you just replaced? or the new IAT sensor went bad (not likely, but possible). Did you get the same code when it went back to hard shifting?
Old 07-06-2007, 11:27 PM
yes, same code.... so very strange, i took the sensor out, and checked the connections, looked out, unhooked the battery... put sensor back in... reconnected battery... drove fine, few minutes later SEL went off... shifting went rough again, then.. SEL came back on... same code...
Old 07-07-2007, 07:27 PM
scoopy03 scoopy03 is offline
check to make sure you dont have a vaccum hose loose. i had that happen in my 4cyl and it made it so hard to put it in gear without getting thrown around.
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
Old 07-07-2007, 07:33 PM
it would be good to know if it is L4 or v6 though
Old 07-07-2007, 08:28 PM
khayward2004 khayward2004 is offline
when i replaced my iat sensor the same thing happened, it ended up that the wires and connection should be replaced at the same time, i got them from a dealer for under $20
Old 07-09-2007, 11:05 AM
its a V6.
Old 07-09-2007, 12:44 PM
I'm having a tendency to agree that it sounds like a bad connector, even though it might look good. I know they sell these aftermarket on Rockauto.com. They wouldn't bother selling stuff like this if there wasn't a demand.
The only other thing I can think would be like I said before, possibly a faulty IAT sensor off the shelf.
Old 07-09-2007, 01:21 PM
apparently there is a technical service bulletin about changing the connector as apparently they have had issues with them
Old 07-14-2007, 09:23 PM
Iflylow's Avatar
Iflylow Iflylow is offline
TSB 02-07-30-022B issued 10-2003.
