Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Register FAQ Social Groups
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-27-2006, 08:56 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
idle problem
so when i start the car in the morining the idle is about 1300rpm, then slowly comes down to around 850 rpm. the problem is, after driving for long orsomething even sort periods of time, the car will idle at around 1000rpm. what I dont get is, the car can idle all day at around 850rpm with no problem. is it the tps? im not to sure because the car is fine prier to driving. thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 12-27-2006, 10:47 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: idle problem
Have you adjusted the throttle cable? It sounds like it may be a tad too tight and takes awhile for it to "settle" into place at a regular idle. I'd check that first.
95 Talon TSI AWD
97 Eclipse GST
Old 12-27-2006, 11:09 PM
Re: idle problem
Ill check first thing in the morning. thanks
1997 Eclipse GS-T
Old 12-28-2006, 12:26 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: idle problem
It's either that or the IAC. Pull that and clean out the throttle body and IAC.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
