| Register | FAQ | Social Groups |
| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
does anyone know in a 95 eclipse non turbo gs 5-speed why when its judt driving down the hyway it cuts off and has no throttle resopnce like the engine dies for a few moments then comes back like nothing happend?
Re: running issues
could be lots of things...
ignition, bad gas, need of a tuneup, ecu... need more detail...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
Re: running issues
Not enough info in here to even make a good guess. You should be getting a CEL from this so go and have the codes read then you should be able to fix the problem. Other than that how long has it been since regular maintenance was done?
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: running issues
i change the plugs every 6 months, change the oil every 1500 miles, flush the cooling system every 6 months, and run shell's good stuff in it the car will act up after 20 or30 miles on the hyway and will repeat randomly while driving between 55 and 85
Re: running issues
Is your check engine light??
Re: running issues
the light is on but it has been on because it has a vacume leak its very small and hard to get to so i left it alone so with out a code reader i dont know that the new issue is putting one out
Re: running issues
then see how things go
Re: running issues
Go to advanceauto and get the codes read on that check engine light. Then fix the vac. leak and see if anything new comes up.
| Thread Tools | |
