Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Register FAQ Social Groups
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-13-2006, 05:39 PM
Killa's Avatar
Killa Killa is offline
What happent if you strip the valve cover threat ?
Last couple week, when I was doing valve cover job, I unbolt all the bolt accept one, that I fell it came off too easy, and find out that hafl of the threat on the head is trip, but I still can tight the bolt down, and other day when I was doing boost leak test, I loose pressure on the bolt, and saw little oil split out, is there another option that I can make that bolt hold down better ? beside rethreat the hold on the head.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-13-2006, 06:19 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: What happent if you strip the valve cover threat ?
Not really. You can get a tap and try fix the threads in the hole, but you can't re-thread them to the same size.
95 Talon TSI AWD
97 Eclipse GST
Old 11-13-2006, 06:45 PM
Killa's Avatar
my SS bolt just came today, and I will install it tomorrow, after getting my car back from the dealer. by the way its illegal to run the car without headlight in the day time ? cause I was scrare every time I take my car to the road. headlight will come on wed.
GM FOR LIFE !!
95 camaro lt1
Old 11-13-2006, 08:16 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Yes, it's illegal to drive without headlights...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-13-2006, 09:54 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
really? i never knew that. over here i see crazy things like people driving a car that was in accident(realy bad) with now front bumper, some with no fenders and headlights i dont know how they get away with it.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 11-13-2006, 10:01 PM
Killa's Avatar
you remind me about car accident, I saw a red neon turbo just like pr_ricer had, he was back off me, it look fucking nice, until he pass by, whole fucking rear bumper was complete got hit, I mean the whole trunk was gone . Just like some one jam him in 100mph.
GM FOR LIFE !!
95 camaro lt1
Old 11-13-2006, 11:11 PM
Technically, that car should not be on a public road. They could get fined for driving it. Just like if you have a headlight or taillight out, it's a safety precaution and they will ticket you for that if they feel like being a dick and not giving you just a warning to get it fixed.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 11-14-2006, 08:01 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
On The contrare. Buy a helicoil kit. Here's the VFAQ that explains what to do to use the helicoil. Basically, you drill into the head (straight down), and then you tap it (with the included tap), then use the tool to thread the SS helicoil down into the head, and it's fixed. Now the threads are SS and stronger than before...
In some states it is not illegal. I know that in Virginia there's a law that says you can drive during the day without headlights. There's also an inspection you can get for day time only driving. The only lights that have to work are the brake lights.
You will need to check with your local DMV.
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 11-14-2006, 10:56 PM
I usually helicoil everything that strips out, but I dont' know if I would trust it in the head. If you get even the smallest shaving from drilling out the hole in the head, you could fuck up ALOT of shit. Ah fuck it, just helicoil all of them and you won't have to worry about it ever again.
95 Talon TSI AWD
97 Eclipse GST
Old 11-14-2006, 11:03 PM
Killa's Avatar
Just redid the valve cover gasket install, with new SS valve cover bolt. And flush the redline stuff off the tranny, and run stray pennzoil for the winter, and flush out the transfer case, and put in redline, 1 question, do transfer case need to break in period ? I mean when I flush the first time I can see alot very tiny metal thing, so I put in new fluid and flush it again, and again until 1 ran out of 1 quart ( cheap transfer case oil ), and i saw less metal each time I flush, and im running redline, you think I should changing oil soon ?
GM FOR LIFE !!
95 camaro lt1
Old 11-15-2006, 07:25 AM
Mikelb's Avatar
I helicoiled all the outer bolts on my vc...two of them had stripped out, now they should all be better than stock...
