Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-24-2006, 02:55 PM
ericjunkman ericjunkman is offline
Exclamation Manual Transmission Woes
I recently bought "3 months ago" a 2001 SL 1 and have been extremly happy with it until lately. When I get up in the morning when it is cold my transmission grinds a little while shifting into second. When I slowly shift into second gear and take my time it doesn't do it and once the engine runs a while and has a chance to warm up it shifts fine. I have checked my fluid, it is clean looking and is at an acceptable level and my tranny isnt leaking but I don't know where to go from here. Does anybody have any suggestions or has had this happen before, any input would be awesome, thanks.
Old 10-24-2006, 04:18 PM
drew300 drew300 is offline
Re: Manual Transmission Woes
I don't know if this will help, but a while back I blew a shift into 2nd. I wasn't racing, just shifting thru an intersection. Then I noticed that the shifter was very stiff moving. Everything worked, so I was careful on the way home. I sprayed white lithium grease where the shifter cables meet the bits that change gears at the transmission, and worked it around by shifting gears. (engine off)
After a short while, it freed up and has been good ever since.
I'm thinking perhaps the heavy rain that may have had something to do with the fault.
I just thought, since you bought it used, maybe check that it's got the right oil in it. My manual shift calls for automatic transmission fluid, not the old standard 90 weight.
Old 10-24-2006, 07:59 PM
no it has the correct trans fluid. it was put in a saturn dealership about 20,000 miles ago. I have the paperwork of everything they did to it because they always took it back to the dealership where they bought it. Im afraid it might have to do with the 2nd gear sycnro but pray that its not.
Old 10-25-2006, 11:53 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
your hydraulics could be bad, or clutch.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 10-25-2006, 03:28 PM
but it is always second gear none of the others, ever
Old 01-07-2007, 06:53 PM
unique42160 unique42160 is offline
I have a 99 saturn sc1 abd gear 1 and gear 2 is not working properly, the rpm's goes up to 3 and will not shift down. Help
Old 01-07-2007, 07:09 PM
Angry Re: Manual Transmission Woes
Old 01-07-2007, 07:11 PM
The check engine light is also on, high rpm while driving, rpm goes up to three and won't idle down.
Old 01-08-2007, 12:26 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Unique, please start a new thread about your problem instead of resurecting old threads. AF members can give you better answers this way. Also, please wait more then a few minutes between posts, we arn't that fast.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
