| Register | FAQ | Social Groups |
Big problem, Fuel and Spark issue
Sorry it's me again (>;_<), I have a 1990 RS camaro, with 305 tbi top end setup,Bottomend 350 bore .60, but the computer is 1989. The problem has always been, it cranks "Turns over", but the injectors won't fire right up. If i spray some Starter Fluid, it fires straight up, but now. There's no spark from the coil, i tried a spare coil "still no spark".
The Fuel pump is sending fuel, but the injectors aren't pumping, and now there's no spark. I'm really stomp on this 1, what can cause the injectors not to work and what cause the coil not to have any fire?It had set a Code: 43 at 1 points, but that was because the distrubtor had turn, while i was driving. |
Re: Big problem, Fuel and Spark issue
Check the Batt feed wire to the dist and make sure you have 12V with the key on.
Yeah that was the problem man, The wires pink and white wire from the distrubtor, was broken inside the instulation. It has plenty of spark now, but still sometimes i have to spray Starter Fluid in the TBI unit.
Cool beans, might just be a bit advanced tho
| Thread Tools | |
